Leejo2005 Member
Posted: Sat Mar 19, 2011 8:12 pm Post subject: Head swap progress |
Well my head swap has taken a day longer than I was hoping due to me not having another vehicle at the house right now and murpy's law leading me to require multiple visits to the local part store. I have the intake installed now but it's late, and dark outside and I still want to give everything a good once over before attempting to fire it up. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383 |
Posted: Sat Mar 19, 2011 8:26 pm Post subject: |
ohhh shiney!
What heads did you go with again? Did you just put a 383 in?
Sorry if I am getting peoples projects mixed up.
-Schultzy |
Leejo2005 Member
Posted: Sat Mar 19, 2011 8:36 pm Post subject: |
This is just my lil 305. They're Trick Flow 175's _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Posted: Sat Mar 19, 2011 8:38 pm Post subject: |
Nice heads. What cam did you go with?
-Schultzy |
Leejo2005 Member
Posted: Sat Mar 19, 2011 8:46 pm Post subject: |
Comp Cams 08-501-8. I didn't really want to go too much bigger as it will ultimately be restricted by the tpi intake and this is still my driver. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Posted: Sat Mar 19, 2011 8:49 pm Post subject: |
| I think that is a pretty good 305 cam. That is one of the cams I was looking to go with, but ended up with an UltraDyne instead of the comp. |
Leejo2005 Member
Posted: Sat Mar 19, 2011 10:46 pm Post subject: |
On a somewhat related note. I was messing with my AC harness and the hard black plastic line that supplies vacuum to the damper controls popped off and I can't see where it goes to. I've been looking in the factory service manual and I can't find where the connector on the interior is. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Posted: Sat Mar 19, 2011 10:49 pm Post subject: |
| It turns purple somewhere in the harness IIRC, and goes into the back of the HVAC selector. |
Leejo2005 Member
Posted: Sat Mar 19, 2011 10:59 pm Post subject: |
Sweet. I guess I'll trace the purple line to it's end and plug it in. Thanks! _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Leejo2005 Member
Posted: Sun Mar 20, 2011 9:39 pm Post subject: |
So I got it running today and drove it to my mother in laws house in bothell and now either I have a serious short somewhere or my charging system isn't working. I'm going to have to wait till morning to figure out what it is. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Leejo2005 Member
Posted: Mon Mar 21, 2011 11:24 am Post subject: |
New alternator and it's fixed. Taking her to Leavenworth today and see how the thing works. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Leejo2005 Member
Posted: Tue Mar 22, 2011 8:59 pm Post subject: |
So I got it to Leavenworth just fine. The only issues I have is it like to surge under low load and low rpm and speed and it runs a bit rough under medium load starting at about 2500. I think cyl 4 plug wire might be bad it looks like it may have been cooked. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
Posted: Tue Mar 22, 2011 9:17 pm Post subject: |
What size valves do those heads have? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Awesome to hear the initial voyage went well! Good luck on figuring out the drivability quirks, that's always fun.  _________________
Leejo2005 Member
Posted: Tue Mar 22, 2011 9:58 pm Post subject: |
I believe the intakes are 1.94 and exhaust are 1.50
Hopefully it doesn't take much. It is still plenty fun to drive. _________________ 2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
