		| Author | Message |
		| Leejo2005 Member
				|  Posted: Sat Mar 19, 2011 8:12 pm    Post subject: Head swap progress |   |
				| Well my head swap has taken a day longer than I was hoping due to me not having another vehicle at the house right now and murpy's law leading me to require multiple visits to the local part store. I have the intake installed now but it's late, and dark outside and I still want to give everything a good once over before attempting to fire it up. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
 1967 Satellite Sport 383
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Sat Mar 19, 2011 8:26 pm    Post subject: |   |
				| ohhh shiney!
 What heads did you go with again? Did you just put a 383 in?
 Sorry if I am getting peoples projects mixed up.
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Mar 19, 2011 8:36 pm    Post subject: |   |
				| This is just my lil 305. They're Trick Flow 175's _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Sat Mar 19, 2011 8:38 pm    Post subject: |   |
				| Nice heads. What cam did you go with?
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Mar 19, 2011 8:46 pm    Post subject: |   |
				| Comp Cams 08-501-8. I didn't really want to go too much bigger as it will ultimately be restricted by the tpi intake and this is still my driver. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Sat Mar 19, 2011 8:49 pm    Post subject: |   |
				| I think that is a pretty good 305 cam.  That is one of the cams I was looking to go with, but ended up with an UltraDyne instead of the comp. |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Mar 19, 2011 10:46 pm    Post subject: |   |
				| On a somewhat related note. I was messing with my AC harness and the hard black plastic line that supplies vacuum to the damper controls popped off and I can't see where it goes to. I've been looking in the factory service manual and I can't find where the connector on the interior is. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sat Mar 19, 2011 10:49 pm    Post subject: |   |
				| It turns purple somewhere in the harness IIRC, and goes into the back of the HVAC selector. |  |
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sat Mar 19, 2011 10:59 pm    Post subject: |   |
				| Sweet. I guess I'll trace the purple line to it's end and plug it in. Thanks! _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Sun Mar 20, 2011 9:39 pm    Post subject: |   |
				| So I got it running today and drove it to my mother in laws house in bothell and now either I have a serious short somewhere or my charging system isn't working. I'm going to have to wait till morning to figure out what it is. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Mon Mar 21, 2011 11:24 am    Post subject: |   |
				| New alternator and it's fixed. Taking her to Leavenworth today and see how the thing works. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Tue Mar 22, 2011 8:59 pm    Post subject: |   |
				| So I got it to Leavenworth just fine. The only issues I have is it like to surge under low load and low rpm and speed and it runs a bit rough under medium load starting at about 2500. I think cyl 4 plug wire might be bad it looks like it may have been cooked. _________________
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
		| RSFreak The other "John"
 1989  Chevrolet  Camaro RS
				|  Posted: Tue Mar 22, 2011 9:17 pm    Post subject: |   |
				| What size valves do those heads have? _________________
		| Back to top |  |
		| iansane Member
 1991  Pontiac  Trans Am
				| Awesome to hear the initial voyage went well! Good luck on figuring out the drivability quirks, that's always fun.  _________________
		| Back to top |  |
		| Leejo2005 Member
				|  Posted: Tue Mar 22, 2011 9:58 pm    Post subject: |   |
				| I believe the intakes are 1.94 and exhaust are 1.50
 Hopefully it doesn't take much. It is still plenty fun to drive.
 2010 Cobalt LT
 1999 Taurus SHO
 1974 F-250 460
		| Back to top |  |
