New guy looking for a little help. Got some data logging!
PostPosted: Thu Apr 26, 2007 8:25 pm    Post subject: Reply with quote
Mitch,
It was nice meeting you. I was chatting with Chevymad tonight, about your problem.
He mentioned how the trucks have lots of EGR problems. Considering our converstion, I think that might be a great place to look.
I am sure he'll go into more detail, but its another suggestion. If we end up doing a chip for your rig, you could do the full EGR delete then too...
--John
(BTW, now we need to talk you into buying a f-body... Wink)
PostPosted: Thu Apr 26, 2007 8:53 pm    Post subject: Reply with quote
yeah, if you are real attached to that engine we could put it in you future Firebird. Wink
PostPosted: Thu Apr 26, 2007 8:54 pm    Post subject: Reply with quote
pff, get an f-body to race, and tow it with the burban.
PostPosted: Thu Apr 26, 2007 9:27 pm    Post subject: Reply with quote
Yup yup
PostPosted: Thu Apr 26, 2007 9:28 pm    Post subject: Reply with quote
plus if you want to go fast buy a Camaro instead of a Bird. USA
PostPosted: Thu Apr 26, 2007 9:41 pm    Post subject: Reply with quote
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Razz
PostPosted: Thu Apr 26, 2007 9:48 pm    Post subject: Reply with quote
yeah you're right Rodney. the rolling brick known as firebird just can't keep up with the sleek aero-dynamics of the Camaro and it's headlight pockets. Laughing
a bird says "Tweet"
PostPosted: Thu Apr 26, 2007 9:52 pm    Post subject: Reply with quote
I think that sounds like a tutu bet, with Tony and Rodney at the race track.
PostPosted: Thu Apr 26, 2007 10:20 pm    Post subject: Reply with quote
sure, i bet my car is more Aero-dynamic in a wind tunnel then his Very Happy but that is where the superiority of my Firebird ends. well, looks too i suppose. Cool
PostPosted: Sat Apr 28, 2007 6:32 am    Post subject: Reply with quote
Laughing
y5mgisi
PostPosted: Sun Apr 29, 2007 9:52 am    Post subject: Reply with quote
Laughing Hey dudes sorry it took me so long to get back on here but its a pain finding time for the computer when you work 12 hour days. Anyway, about the egr, just as an FYI, When i fineshed putiing together the motor i put on a new EGR valve and hooked it all up right. It still had the off idle issues as the old egr had. So i unhooked it and capped of the vac line from the egr solonoid to the egr. I then was convinced that perhaps my new egr was in a stuck upoen position so i put my old one back on (still unhooked) and it still ran the same as the day you two seen it.
90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains.
y5mgisi
PostPosted: Mon Aug 30, 2010 4:16 pm    Post subject: Reply with quote
SO... 3 years later and im still having the same problem. Actually its gotten even worse. I finally checked the compression and came up with about 130psi in all 8 and the plugs are all black. Has something like 7000 miles on the motor now... So last time John, Tony, and I met up we were un able to data log. I forget why now, but im wondering if anyone would want to give er another shot at logging and reading the results?
Really starting to think about putting a stock cam in it.
izcain
9sec Club
PostPosted: Wed Sep 01, 2010 8:58 pm    Post subject: Reply with quote
What are the cam specs on this motor?
What is the static compression ratio when you assembled the motor?
IAC??? Would be interesting to see the live data when the problem occurs.
9.17 @ 148
y5mgisi
PostPosted: Wed Sep 01, 2010 9:15 pm    Post subject: Reply with quote
heres cam specs
Basic Operating RPM Range: Idle-5,500 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
The C/R im honestly not sure about. Seems to me if i remember right that the pistons had a slight dish to them but MAY have been flat tops. the heads were stock but possibly re surfaced. So, im ASSuming 8.5:1-9:1.
At some point way back when i had put it on the scanner and here is what it found back then. I will have to try again here soon.
promID: 4551
IAC:39steps
temp:165.2
open loop
TPS: .62 volts
Intergrater: 128
O2:448mVolts
Knock: 0
Block learn: 126
o2 cross count:174 and rising quickly.
PostPosted: Sat Sep 04, 2010 9:50 am    Post subject: Reply with quote
WOW, blast from the past. Blue 90's burb right?
y5mgisi
PostPosted: Sun Sep 05, 2010 7:58 pm    Post subject: Reply with quote
That is correct!
y5mgisi
PostPosted: Tue Sep 21, 2010 9:19 pm    Post subject: Reply with quote
So i hate to seem like a whiney helpless loser, but im wondering if anyone still has any desire to do some data logging with me on my truck. I built my data cable only to find that my laptop has the wrong stinkin serial connector! Guess im just trying to be a cheapo before i shell out for a serial-usb adapter.
PostPosted: Tue Sep 21, 2010 11:36 pm    Post subject: Reply with quote
I can plug in and look at the data. The hard part is finding a time that works with my schedule.
--John
y5mgisi
PostPosted: Wed Sep 22, 2010 12:12 am    Post subject: Reply with quote
Yea I feel ya there...I work. 2:30 to 11 Monday -friday. And most the time on the weekends too...
PostPosted: Wed Sep 22, 2010 12:57 am    Post subject: Reply with quote
Yeah, I work 11pm-9am Mon-Thurs. Maybe we can find a weekend day coming up that would work.
Page 2 of 3
