Posted: Thu Apr 26, 2007 8:25 pm Post subject: |
Mitch,
It was nice meeting you. I was chatting with Chevymad tonight, about your problem.
He mentioned how the trucks have lots of EGR problems. Considering our converstion, I think that might be a great place to look.
I am sure he'll go into more detail, but its another suggestion. If we end up doing a chip for your rig, you could do the full EGR delete then too...
--John
(BTW, now we need to talk you into buying a f-body... ) |
Posted: Thu Apr 26, 2007 8:53 pm Post subject: |
yeah, if you are real attached to that engine we could put it in you future Firebird.  |
Posted: Thu Apr 26, 2007 8:54 pm Post subject: |
| pff, get an f-body to race, and tow it with the burban. |
Posted: Thu Apr 26, 2007 9:27 pm Post subject: |
| Dewey316 wrote: | | pff, get an f-body to race, and tow it with the burban. |  |
Posted: Thu Apr 26, 2007 9:28 pm Post subject: |
| Xophertony wrote: | yeah, if you are real attached to that engine we could put it in you future Firebird.  |
plus if you want to go fast buy a Camaro instead of a Bird.  |
Posted: Thu Apr 26, 2007 9:41 pm Post subject: |
Posted: Thu Apr 26, 2007 9:48 pm Post subject: |
yeah you're right Rodney. the rolling brick known as firebird just can't keep up with the sleek aero-dynamics of the Camaro and it's headlight pockets.
a bird says "Tweet" |
Posted: Thu Apr 26, 2007 9:52 pm Post subject: |
| I think that sounds like a tutu bet, with Tony and Rodney at the race track. |
Posted: Thu Apr 26, 2007 10:20 pm Post subject: |
sure, i bet my car is more Aero-dynamic in a wind tunnel then his but that is where the superiority of my Firebird ends. well, looks too i suppose.  |
Posted: Sat Apr 28, 2007 6:32 am Post subject: |
| Dewey316 wrote: | | I think that sounds like a tutu bet, with Tony and Rodney at the race track. |
y5mgisi Member
Posted: Sun Apr 29, 2007 9:52 am Post subject: |
Hey dudes sorry it took me so long to get back on here but its a pain finding time for the computer when you work 12 hour days. Anyway, about the egr, just as an FYI, When i fineshed putiing together the motor i put on a new EGR valve and hooked it all up right. It still had the off idle issues as the old egr had. So i unhooked it and capped of the vac line from the egr solonoid to the egr. I then was convinced that perhaps my new egr was in a stuck upoen position so i put my old one back on (still unhooked) and it still ran the same as the day you two seen it. _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
y5mgisi Member
Posted: Mon Aug 30, 2010 4:16 pm Post subject: |
SO... 3 years later and im still having the same problem. Actually its gotten even worse. I finally checked the compression and came up with about 130psi in all 8 and the plugs are all black. Has something like 7000 miles on the motor now... So last time John, Tony, and I met up we were un able to data log. I forget why now, but im wondering if anyone would want to give er another shot at logging and reading the results?
Really starting to think about putting a stock cam in it. _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
izcain 9sec Club
Posted: Wed Sep 01, 2010 8:58 pm Post subject: |
What are the cam specs on this motor?
What is the static compression ratio when you assembled the motor?
IAC??? Would be interesting to see the live data when the problem occurs. _________________
9.17 @ 148 |
y5mgisi Member
Posted: Wed Sep 01, 2010 9:15 pm Post subject: |
heres cam specs
Basic Operating RPM Range: Idle-5,500 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
The C/R im honestly not sure about. Seems to me if i remember right that the pistons had a slight dish to them but MAY have been flat tops. the heads were stock but possibly re surfaced. So, im ASSuming 8.5:1-9:1.
At some point way back when i had put it on the scanner and here is what it found back then. I will have to try again here soon.
promID: 4551
IAC:39steps
temp:165.2
open loop
TPS: .62 volts
Intergrater: 128
O2:448mVolts
Knock: 0
Block learn: 126
o2 cross count:174 and rising quickly. _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
Posted: Sat Sep 04, 2010 9:50 am Post subject: |
| WOW, blast from the past. Blue 90's burb right? |
y5mgisi Member
Posted: Sun Sep 05, 2010 7:58 pm Post subject: |
That is correct! _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
y5mgisi Member
Posted: Tue Sep 21, 2010 9:19 pm Post subject: |
So i hate to seem like a whiney helpless loser, but im wondering if anyone still has any desire to do some data logging with me on my truck. I built my data cable only to find that my laptop has the wrong stinkin serial connector! Guess im just trying to be a cheapo before i shell out for a serial-usb adapter. _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
Posted: Tue Sep 21, 2010 11:36 pm Post subject: |
I can plug in and look at the data. The hard part is finding a time that works with my schedule.
--John |
y5mgisi Member
Posted: Wed Sep 22, 2010 12:12 am Post subject: |
Yea I feel ya there...I work. 2:30 to 11 Monday -friday. And most the time on the weekends too... _________________ 90 chev suburban 3/4ton 4x4, stock, rebuilt 350 w/TBI,th400, 3.73 gears, 33" pro comp mud terrains. |
Posted: Wed Sep 22, 2010 12:57 am Post subject: |
| Yeah, I work 11pm-9am Mon-Thurs. Maybe we can find a weekend day coming up that would work. |
