BigDaddyVu 12sec Club
Posted: Sat Sep 08, 2007 12:01 am Post subject: Car Craft featured a turbocharged 3rd gen in spokane |
well my friend got his car in car craft the low buck turbo charged firebird( hes the one was giving me ideas on turbo charging).
http://www.spokanespeed.net/forum/showthread.php?t=2132 |
Posted: Sat Sep 08, 2007 1:40 pm Post subject: |
| BigDaddy, email me those pics and I can host them so people don't have to register. |
Posted: Sat Sep 08, 2007 6:22 pm Post subject: |
Posted: Sat Sep 08, 2007 9:16 pm Post subject: |
Thanks man.
That car looks great. |
Posted: Sat Sep 08, 2007 11:48 pm Post subject: |
That car is pure awesome. _________________
Posted: Sun Sep 09, 2007 12:01 am Post subject: |
| I just got the mag and it is very interesting story. i known the the guy for 10 years and even helped me tuned my T/A when i used to live near tims hot rod. |
Posted: Mon Sep 10, 2007 8:24 am Post subject: |
| anyone have any idea as to what he used to control fuel? |
Posted: Mon Sep 10, 2007 9:04 am Post subject: |
its a TT-TPI-TA nice _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
Posted: Mon Sep 10, 2007 9:12 am Post subject: |
| aeromotive just like what i have |
Posted: Mon Sep 10, 2007 11:10 am Post subject: |
| the FMU will function the same for turbo's or supercharges, it raises the fuel pressure by a ratio to the boost pressure. Its an OK system, not ideal IMHO, but on a carbed setup, you don't have any choice but to run a blowthrough carb, and raise the pressure enough to fill the bowls. |
Posted: Mon Sep 10, 2007 11:40 am Post subject: |
Is that all you have to do? But that would only work with no-return fuel systems....
Wouldn't it be cheaper to get a rising fuel rate fuel pressure regulator instead? |
Posted: Mon Sep 10, 2007 11:46 am Post subject: |
Yes, you could just get an adjustable FMU from someone like Vortec. I dont' know the price on the aeromotive unit, so I can't say which would be cheaper.
Just for the record, I don't like the FMU being the only way to control fueling under boost. I would much rather have a computer capable of reading 2bar, so that you can have better control over timing and fueling under boost. If you go this route, all you can do is use the FMU, and then get something like the MSD BMT to pull timing based on boost levels.
For a blow-through carb setup, this is about your only option, but on a FI car, I would much rather do it the right way.
--John |
Posted: Mon Sep 10, 2007 4:25 pm Post subject: |
well the msd boost timing only controls the retard on a lock out dizzy under boost. On the aeromotive fuel pressure reg it reads the boost signal to mantain a constand 5 to 7 psi of fuel over the boost for example on a non boosted carb or at idle on a boosted carb your psi runs around 5 to 7 psi now with an added boost lets say your running 10 psi of boost your fuel will be at 16 psi just to keep the fuel being pushed back into the tank and it is proportional to the psi levels and it does have a return it acts like an efi reg. the factory reg can't read boost cuz it can only read vacuum. Now the 2 bar map(turbo sunbird 4 banger) up to 15 psi of boost and/or (turbo T/A, typhoon,cyclone, and GN's family)3 bar map up to 44 psi of boost only senses boost for factory fuel curve and electronic timing on efi. don't get me wrong but efi does run more perfectly than a blow through setup.
If your curious how the system work check this forum out first. http://www.theturboforums.com/smf/index.php |
