Getting to work on a F-Body
PostPosted: Fri May 25, 2012 5:17 pm    Post subject: Getting to work on a F-Body Reply with quote
Dad's rig was in dire need of front end work. All bushings were split or missing all together - Control arms, sway bars, ball joints etc. Thing clunked when you hit the brakes from the sway bar whacking the frame even. Ripped it all off and found something I'd never seen before!
Behold! The bent spring!
Think some Summit progressive springs, some Moog chassis components, and if $ allows a nice new front sway bar set.
PostPosted: Fri May 25, 2012 5:21 pm    Post subject: Reply with quote
Wow. Does it look heated or played with?
PostPosted: Fri May 25, 2012 6:54 pm    Post subject: Reply with quote
Nope. Just kinked. So weird.
PostPosted: Fri May 25, 2012 8:32 pm    Post subject: Reply with quote
Wow. That's impressive. Did it sag or anything on one side?
PostPosted: Fri May 25, 2012 8:53 pm    Post subject: Reply with quote
No sagging or anything just clunk and some wander steer.
PostPosted: Fri May 25, 2012 9:00 pm    Post subject: Reply with quote
It's not really shorter, just bent-er. Laughing
If it wasn't torched it was probably just a bad part off the line and it failed sometime in the past forty years of service.
PostPosted: Fri May 25, 2012 9:02 pm    Post subject: Reply with quote
Wow. Johnny is in for a real treat when you are done with that!
PostPosted: Sat May 26, 2012 4:36 am    Post subject: Reply with quote
My 1ton had something like that on the right. Made it sag in that cornor.
PostPosted: Sat May 26, 2012 7:21 pm    Post subject: Reply with quote
If he needs any stock parts I have some left over pieces, though not many.
PostPosted: Sat May 26, 2012 7:37 pm    Post subject: Reply with quote
Thanks. All the hard parts are fine (spindles, arms, etc)
I'm going to get to cleaning them up this week.
PostPosted: Sun May 27, 2012 9:14 am    Post subject: Reply with quote
I just remembered, there's been an ad on craigs for some performance fbody suspension parts. Ad has been on there for months and months.. price is out of my range, but he has new springs front and rear, sway bars, steering components etc.. Hotchkis brand.
http://portland.craigslist.org/clk/pts/2982396870.html
PostPosted: Sun May 27, 2012 10:24 am    Post subject: Reply with quote
Wow he's rather over priced!
PostPosted: Thu May 31, 2012 2:03 pm    Post subject: Reply with quote
Upper ball joint appear to be riveted in? Never seen this before. Do the new ones just come with bolts?
PostPosted: Thu May 31, 2012 4:22 pm    Post subject: Reply with quote
Yes, all factory uppers are riveted. Replacements have bolts. Sucks for a matching resto.
PostPosted: Thu May 31, 2012 4:27 pm    Post subject: Reply with quote
IMHO that shouldn't matter for a resto. Anyway, with a 5 speed, there's nothing "resto" about this car. :O)
Time to get out the grinder. At least that's two less things to press in.
PostPosted: Thu May 31, 2012 7:31 pm    Post subject: Reply with quote
Cavalier was that way. Wink Factory service manual directs you to drill them out and bolt new ones in.
PostPosted: Fri Jun 01, 2012 5:37 am    Post subject: Reply with quote
Unless you have a 2004 base model silverado. Uppers bolted, lowers rivited.
PostPosted: Fri Jun 01, 2012 9:07 am    Post subject: Reply with quote
Newer vehicles are totally different. They dont even use stamped a-arms like before.
But everything that used stamped a-arms had the upper riveted balljoints.. At least that I can think of. S10, C10-20, A-body, fbody, nova.. etc.
PostPosted: Fri Jun 01, 2012 4:12 pm    Post subject: Reply with quote
You didnt say newer, you said all Wink
But yea, s10, montes, novas, my 97 c3500 did too. But that 04 thru me for a effing loop.
PostPosted: Fri Jun 01, 2012 4:27 pm    Post subject: Reply with quote
Guess I don't remember, or have some how never gotten to factory ball joints!
