Posted: Fri May 25, 2012 5:17 pm Post subject: Getting to work on a F-Body |
Dad's rig was in dire need of front end work. All bushings were split or missing all together - Control arms, sway bars, ball joints etc. Thing clunked when you hit the brakes from the sway bar whacking the frame even. Ripped it all off and found something I'd never seen before!
Behold! The bent spring!
Think some Summit progressive springs, some Moog chassis components, and if $ allows a nice new front sway bar set. _________________ A redline a day keeps the carbon away! |
Posted: Fri May 25, 2012 5:21 pm Post subject: |
| Wow. Does it look heated or played with? |
Posted: Fri May 25, 2012 6:54 pm Post subject: |
Nope. Just kinked. So weird. _________________ A redline a day keeps the carbon away! |
Posted: Fri May 25, 2012 8:32 pm Post subject: |
Wow. That's impressive. Did it sag or anything on one side? _________________
Posted: Fri May 25, 2012 8:53 pm Post subject: |
No sagging or anything just clunk and some wander steer. _________________ A redline a day keeps the carbon away! |
Posted: Fri May 25, 2012 9:00 pm Post subject: |
It's not really shorter, just bent-er.
If it wasn't torched it was probably just a bad part off the line and it failed sometime in the past forty years of service. |
Posted: Fri May 25, 2012 9:02 pm Post subject: |
Wow. Johnny is in for a real treat when you are done with that!
Posted: Sat May 26, 2012 4:36 am Post subject: |
My 1ton had something like that on the right. Made it sag in that cornor. _________________ 2008 GMC Z71
Posted: Sat May 26, 2012 7:21 pm Post subject: |
| If he needs any stock parts I have some left over pieces, though not many. |
Posted: Sat May 26, 2012 7:37 pm Post subject: |
Thanks. All the hard parts are fine (spindles, arms, etc)
I'm going to get to cleaning them up this week. _________________ A redline a day keeps the carbon away! |
Posted: Sun May 27, 2012 9:14 am Post subject: |
I just remembered, there's been an ad on craigs for some performance fbody suspension parts. Ad has been on there for months and months.. price is out of my range, but he has new springs front and rear, sway bars, steering components etc.. Hotchkis brand.
http://portland.craigslist.org/clk/pts/2982396870.html |
Posted: Sun May 27, 2012 10:24 am Post subject: |
Wow he's rather over priced! _________________ A redline a day keeps the carbon away! |
Posted: Thu May 31, 2012 2:03 pm Post subject: |
Upper ball joint appear to be riveted in? Never seen this before. Do the new ones just come with bolts? _________________ A redline a day keeps the carbon away! |
Posted: Thu May 31, 2012 4:22 pm Post subject: |
| Yes, all factory uppers are riveted. Replacements have bolts. Sucks for a matching resto. |
Posted: Thu May 31, 2012 4:27 pm Post subject: |
IMHO that shouldn't matter for a resto. Anyway, with a 5 speed, there's nothing "resto" about this car. :O)
Time to get out the grinder. At least that's two less things to press in. _________________ A redline a day keeps the carbon away! |
Posted: Thu May 31, 2012 7:31 pm Post subject: |
| Twilightoptics wrote: | | Upper ball joint appear to be riveted in? Never seen this before. |
Cavalier was that way. Factory service manual directs you to drill them out and bolt new ones in. |
Posted: Fri Jun 01, 2012 5:37 am Post subject: |
| chevymad wrote: | | Yes, all factory uppers are riveted. Replacements have bolts. Sucks for a matching resto. |
Unless you have a 2004 base model silverado. Uppers bolted, lowers rivited. |
Posted: Fri Jun 01, 2012 9:07 am Post subject: |
| 91RSVert wrote: | | chevymad wrote: | | Yes, all factory uppers are riveted. Replacements have bolts. Sucks for a matching resto. |
Newer vehicles are totally different. They dont even use stamped a-arms like before.
But everything that used stamped a-arms had the upper riveted balljoints.. At least that I can think of. S10, C10-20, A-body, fbody, nova.. etc. |
Posted: Fri Jun 01, 2012 4:12 pm Post subject: |
| chevymad wrote: |
You didnt say newer, you said all
But yea, s10, montes, novas, my 97 c3500 did too. But that 04 thru me for a effing loop. |
Posted: Fri Jun 01, 2012 4:27 pm Post subject: |
Guess I don't remember, or have some how never gotten to factory ball joints! _________________ A redline a day keeps the carbon away! |
