91camaro_rs Member
Posted: Wed Mar 16, 2011 10:22 pm Post subject: |
im pretty sure its blood enterprises and its $90 for 3 pulls _________________
Posted: Wed Mar 16, 2011 10:31 pm Post subject: |
I've heard some horrendous stories about blood. And the only time I went there for some advice/pricing they stuck their nose in the air like thirdgens weren't worth their time. Good luck!  _________________
fiveoformula Member
Posted: Thu Mar 17, 2011 7:22 pm Post subject: |
Well for some reason I can't get the sheet to load up from the disc...
But the bird made 160HP/245LBFT with the AFR just over 12:1 the whole time, and the peak power curve stayed really flat between 3-5K RPM
Now if only I had some more peak power.  _________________
'88 FORMULA |
Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Thu Mar 17, 2011 7:39 pm Post subject: |
If the L03 is anything like an LSx/LTx, I would think 12.1:1 AFR's is a bit on the rich side. Did you try leaning it out a bit more? _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
fiveoformula Member
Posted: Thu Mar 17, 2011 7:46 pm Post subject: |
| I haven't, but yeah 12.8ish would be better, I'll get that dialed a little more, then move onto spark. |
Boostd1 12sec Club
Posted: Thu Mar 17, 2011 7:47 pm Post subject: |
Wouldnt surprise me if you gained alot of power by leaning it out and adding some timing! It's probably good for another 15-20whp. _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Thu Mar 17, 2011 11:34 pm Post subject: |
Might get about 10hp bringing it to around 12.8. _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 18, 2011 5:09 pm Post subject: |
I still don't get why my torque was so low! Anyone? _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Fri Mar 18, 2011 5:33 pm Post subject: |
LT1 cam is not a torque maker. I had a 305 with LT1 cam in it dynoed with an edelbrock carb and that graph looks pretty close. It was like 180hp IIRC and a super flat torque curve.
TPI right?
Might work out those spark tables and get a good clean 38DEG ATDC from 3000rpm on.
Spark has a pretty good role on torque. As does condition of piston rings :O) _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 18, 2011 6:42 pm Post subject: |
| Ive been looking at the specs on a the LT1 cam, and it looks like its fairly decent on the tq side as far as spec wise??? |
Posted: Fri Mar 18, 2011 6:43 pm Post subject: |
| 91RSVert wrote: | | Ive been looking at the specs on a the LT1 cam, and it looks like its fairly decent on the tq side as far as spec wise??? |
Um, how are you finding "torque specs" for a cam? _________________ A redline a day keeps the carbon away! |
IROCDave Member
Posted: Fri Mar 18, 2011 6:47 pm Post subject: |
Nice to see some dyno numbers posted and "good on ya" to the guys that traveled to the gathering.
It aint easey squeezing HP out of an old school SBC with OEM fuel injection engineered in the early 80's. The LSx crowd has a huge leg up from the start. If you want to make decent power with our archaic settups, start with the heads, then cam to match and atleast an 9.5 CR. With this in mind, I am still suprised no one jumped on the TF heads and matched cam I posted awhile ago in the 4 sale section. It would have made more TQ and been close to winning in HP also. This is of course with a 350.
Blue89, the CR is holding you back bigtime. A BBC needs 9.0/1 minimum and a good set of heads. If you really want to wake it up, go with 10.5/1 and lots of duration on the cam. You should NO problem surpassing 400 RWHP / 450 RWTQ with good heads / cam and decent compression. |
fiveoformula Member
Posted: Fri Mar 18, 2011 10:07 pm Post subject: |
| Twilightoptics wrote: | | Might get about 10hp bringing it to around 12.8. |
Really that much?
The butt dyno says its faster than ever (the real dyno too.) Well see what it does at the track next couple weeks, and I'll try and get the AFR leaner.
Best time at PIR is 15.5@ 87, with a 10.something AFR. _________________
'88 FORMULA |
Posted: Fri Mar 18, 2011 10:18 pm Post subject: |
I went from 285RWHP on the dyno at about 11.8:1..... Tuned on the dyno to 305RWHP to 12.8:1. _________________ A redline a day keeps the carbon away! |
Posted: Sat Mar 19, 2011 4:52 am Post subject: |
Um, how are you finding "torque specs" for a cam? |
Ive been reading up on what the numbers mean, and what they normally do. And you can kinda see what the cam SHOULD do. But of course the heads and intake play alot as well. |
Posted: Sat Mar 19, 2011 7:15 am Post subject: |
I wasn't expecting huge numbers, but I am about 30lb-ft below the stock number (at the crank).  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sat Mar 19, 2011 7:50 am Post subject: |
| Twilightoptics wrote: | | 38DEG ATDC |
That might make it run kinda interesting, eh Paul?
I actually just glanced at the chip we downloaded for John's car (should have been a stock LB9 chip) and the timing table is forked! Like 29* from 3K on!
Just goes to show you gotta check everything you download that's supposedly "stock". That chip had crapped up torque converter lock tables as well.  |
Posted: Sat Mar 19, 2011 9:33 am Post subject: |
| aaron_sK wrote: | | Twilightoptics wrote: | | 38DEG ATDC |
lol was at work typing in a hurry.
Double check that chip. There are ALOT of spark tables that add to the main table.
What I do, is Zero out all the other tables so they have no affect, and run everything off the main MAP/LOAD vs RPM.
If things are funky and dont make sense, it's not a good file or definition. _________________ A redline a day keeps the carbon away! |
Posted: Sat Mar 19, 2011 11:46 am Post subject: |
I checked it just now and the PE spark adder tables have already been zeroed. This was obviously a modified chip that some joker put up as a stock BIN.
This is what I get for downloading a BIN from that Davis Z28 site.  |
Posted: Sat Mar 19, 2011 11:50 am Post subject: |
Nice! I guess its time for me to learn to edit my own bin.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
