nonsensekid20 Member
Posted: Sat Feb 05, 2011 10:44 pm Post subject: Car's still runnin rich. |
Posted: Sat Feb 05, 2011 10:50 pm Post subject: |
Less info helps solve problems.  |
Posted: Sat Feb 05, 2011 10:51 pm Post subject: |
| Jets? |
| All I can smell is raw fuel. I ate up 1/4 tank of gas in 30 miles. sweeeet. |
Posted: Sat Feb 05, 2011 10:53 pm Post subject: |
See? More info helped.
Probably not jets if it's that rich. Look for blown power valve or choke stuck shut. |
Posted: Sat Feb 05, 2011 10:56 pm Post subject: |
Not the choke. I can tell it's on when I start the car because it idles at about 1000 rpm or so, then goes down to about 700-800 later.
Is idle mix a possibility? |
RK82 Member
1982 Pontiac Trans Am
Posted: Sun Feb 06, 2011 11:22 am Post subject: |
what engine?
what carb?
like aaron said more info |
Posted: Sun Feb 06, 2011 11:45 am Post subject: |
| nonsensekid20 wrote: | | Is idle mix a possibility? |
Sure. Lots of things are a possibility.
Also, don't look at just the carb. Distributor frozen/misadjusted will cause issues like this. |
Posted: Sun Feb 06, 2011 11:57 am Post subject: |
I'm farting. Why?
See, you can't answer that question either. You need to provide a lot more info when you need help. |
Posted: Sun Feb 06, 2011 12:33 pm Post subject: |
It's Superbowl Sunday, Jon. It's the day God wants you to eat garbage food and fart.  |
Posted: Sun Feb 06, 2011 2:59 pm Post subject: |
True. But I haven't even had any junk food yet today.  |
Posted: Sun Feb 06, 2011 8:18 pm Post subject: |
My dad bent a primary needle rebuilding one of his carbs a couple years ago...
Fuel economy was measured in gallons per mile. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Feb 06, 2011 8:35 pm Post subject: |
Anytime I've seen a Holley's needles clog up it was accompanied by an external fuel leak from the throttle shafts. It is a possibility, though.
Again, more info is needed (bad fuel, run out of fuel, run without filter, monkeys in carb before issue started, ect.) |
Posted: Sun Feb 06, 2011 9:06 pm Post subject: |
Holley Street Avenger. Electric choke.
Chevy 350. Rebuilt. Mild RV cam. GM performace intake. (I think)
If I remember right, Street Avengers have fuel filters built in.
Distributor is a MSD StreetFire.
Everything is brand new. Nothing should be broken/frozen. |
Posted: Sun Feb 06, 2011 9:09 pm Post subject: |
| nonsensekid20 wrote: | | Mild RV cam. |
 _________________ A redline a day keeps the carbon away! |
RK82 Member
Posted: Sun Feb 06, 2011 9:37 pm Post subject: |
| Twilightoptics wrote: | | nonsensekid20 wrote: | | Mild RV cam. |
is that kinda like a 3/4 race cam.....  |
Posted: Sun Feb 06, 2011 10:00 pm Post subject: |
Yo it's got dem full race camz duder.
| nonsensekid20 wrote: | | fuel filters built in |
So do Quadra's. Still gotta put a real filter in there somewhere. Probably not the issue though unless the car got run out of gas or something.
| nonsensekid20 wrote: | | Everything is brand new. Nothing should be broken/frozen. |
Never bet on it. Stuff comes DOA all the time. |
Posted: Sun Feb 06, 2011 10:05 pm Post subject: |
| I bought a Barry Grant Speed Demon and it was full of metal filings. |
RK82 Member
Posted: Mon Feb 07, 2011 8:32 am Post subject: |
| nonsensekid20 wrote: | Holley Street Avenger. Electric choke.
If I remember right, Street Avengers have fuel filters built in. |
they have screens in them but you still need a filter.
| nonsensekid20 wrote: | Distributor is a MSD StreetFire.
hows the rest of the ignition system? plugs,wires,coil?
did you ever get your timing set right?
what fuel pump? fuel pressure? |
Posted: Mon Feb 07, 2011 9:22 am Post subject: |
It's ran outta fuel like once. Fuel pump isnt name brand, but its a manual fuel pump. We got it timed to 800 rpm. NGK plugs if i remember right. coil is built into the distributor.
Whatchu guys talkin about the cam? hah |
