Car's still runnin rich.
Goto page 1, 2, 3, 4  Next
nonsensekid20
PostPosted: Sat Feb 05, 2011 10:44 pm    Post subject: Car's still runnin rich. Reply with quote
Confused
PostPosted: Sat Feb 05, 2011 10:50 pm    Post subject: Reply with quote
Less info helps solve problems. Shrug
nonsensekid20
PostPosted: Sat Feb 05, 2011 10:51 pm    Post subject: Reply with quote
Jets?
nonsensekid20
All I can smell is raw fuel. I ate up 1/4 tank of gas in 30 miles. sweeeet.
PostPosted: Sat Feb 05, 2011 10:53 pm    Post subject: Reply with quote
See? More info helped.
Probably not jets if it's that rich. Look for blown power valve or choke stuck shut.
nonsensekid20
PostPosted: Sat Feb 05, 2011 10:56 pm    Post subject: Reply with quote
Not the choke. I can tell it's on when I start the car because it idles at about 1000 rpm or so, then goes down to about 700-800 later.
Is idle mix a possibility?
RK82
1982 Pontiac Trans Am
PostPosted: Sun Feb 06, 2011 11:22 am    Post subject: Reply with quote
what engine?
what carb?
like aaron said more info
PostPosted: Sun Feb 06, 2011 11:45 am    Post subject: Reply with quote
Sure. Lots of things are a possibility.
Also, don't look at just the carb. Distributor frozen/misadjusted will cause issues like this.
PostPosted: Sun Feb 06, 2011 11:57 am    Post subject: Reply with quote
I'm farting. Why? Confused
See, you can't answer that question either. You need to provide a lot more info when you need help.
PostPosted: Sun Feb 06, 2011 12:33 pm    Post subject: Reply with quote
It's Superbowl Sunday, Jon. It's the day God wants you to eat garbage food and fart. Wink
PostPosted: Sun Feb 06, 2011 2:59 pm    Post subject: Reply with quote
True. But I haven't even had any junk food yet today. Shocked
PostPosted: Sun Feb 06, 2011 8:18 pm    Post subject: Reply with quote
My dad bent a primary needle rebuilding one of his carbs a couple years ago...
Fuel economy was measured in gallons per mile.
PostPosted: Sun Feb 06, 2011 8:35 pm    Post subject: Reply with quote
Anytime I've seen a Holley's needles clog up it was accompanied by an external fuel leak from the throttle shafts. It is a possibility, though.
Again, more info is needed (bad fuel, run out of fuel, run without filter, monkeys in carb before issue started, ect.)
nonsensekid20
PostPosted: Sun Feb 06, 2011 9:06 pm    Post subject: Reply with quote
Holley Street Avenger. Electric choke.
Chevy 350. Rebuilt. Mild RV cam. GM performace intake. (I think)
If I remember right, Street Avengers have fuel filters built in.
Distributor is a MSD StreetFire.
Everything is brand new. Nothing should be broken/frozen.
PostPosted: Sun Feb 06, 2011 9:09 pm    Post subject: Reply with quote
Mild RV cam.
Wedgie time!
RK82
PostPosted: Sun Feb 06, 2011 9:37 pm    Post subject: Reply with quote
Mild RV cam.
Wedgie time!
is that kinda like a 3/4 race cam..... Laughing
PostPosted: Sun Feb 06, 2011 10:00 pm    Post subject: Reply with quote
Yo it's got dem full race camz duder. Wink
So do Quadra's. Still gotta put a real filter in there somewhere. Probably not the issue though unless the car got run out of gas or something.
Never bet on it. Stuff comes DOA all the time.
PostPosted: Sun Feb 06, 2011 10:05 pm    Post subject: Reply with quote
I bought a Barry Grant Speed Demon and it was full of metal filings.
RK82
PostPosted: Mon Feb 07, 2011 8:32 am    Post subject: Reply with quote
they have screens in them but you still need a filter.
hows the rest of the ignition system? plugs,wires,coil?
did you ever get your timing set right?
what fuel pump? fuel pressure?
nonsensekid20
PostPosted: Mon Feb 07, 2011 9:22 am    Post subject: Reply with quote
It's ran outta fuel like once. Fuel pump isnt name brand, but its a manual fuel pump. We got it timed to 800 rpm. NGK plugs if i remember right. coil is built into the distributor.
Whatchu guys talkin about the cam? hah
Page 1 of 4
