		| Author | Message |
		| 91camaro_rs Member
 1991  Chevrolet  Camaro RS
				|  Posted: Sun May 30, 2010 3:58 am    Post subject: ECM tuning |   |
				| so timing my camaro is a lost hope lol, i tried everything to get it perfect but it just wont work, so i called around and my buddy said that the ecm needs to be tuned for the new cam, especially cause its SD not MAF. he recommened Blood enterprises, anyone know of anyone else who can tune the ecm?
 would getting like a stage 2 jet chip work?
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 30, 2010 9:03 am    Post subject: Re: ECM tuning |   |
				|  	  | 91camaro_rs wrote: |  	  | anyone know of anyone else who can tune the ecm?
 Get a laptop, a burner, and get crackin'.
  	  | 91camaro_rs wrote: |  	  | would getting like a stage 2 jet chip work? |
 No.
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sun May 30, 2010 9:28 am    Post subject: |   |
				| a burner? like a prom burner or somthing? where do i get one of those and how in the world do i do it? |  |
		| Back to top |  |
		| aaron_sK Member
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 9:40 am    Post subject: |   |
				| Hello I have a 90 GTA with a warmed up 350 TPI motor.
 i programmed the new chip etc, i.e. i have all the above mentioned stuff and would be glad to help.
 now the bad news.
 its ben a long time since i used this stuff, i will have to relearn. it uses an old DOS laptop.. but it all still works.
 and u will need to come to my place as u can not do this "over the phone"
 i also have a WB 02 setup. sooooo
 let me know whats up.
 i live near Silverdale.
 Mike
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sun May 30, 2010 10:58 am    Post subject: |   |
				| dude that would be awesome if you could help me out are you busy tomorrow? i know its memorial day and most people have plans...well except for me
 if tomorrow works let me know
 would i just need to bring the entire ecm box, i also have the cam spec sheet if that helps at all
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Sun May 30, 2010 11:10 am    Post subject: |   |
				| You'll need the car to tune it. No way to do it right going by specs. I think there's more you'll need as well, but never done it myself. Several people here have done their own tuning though, i'm sure they'll let you know. I think Mangus even wrote the software you'll be using. |  |
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sun May 30, 2010 11:13 am    Post subject: |   |
				| hmmm well i doubt i can get my car up to silverdale haha, i thought you just plugged the prom into the computer and adjust things, do you have to do it while the car is on or something? |  |
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 30, 2010 11:54 am    Post subject: |   |
				| Depends on the setup you use. I ran Moates Burn1 and ZIF socket chips, so chip burning could be done remotely. You need to datalog the car in various situations, then go back and rework the chip as needed. No way it can just be done in an afternoon.
 Let me put it to you this way: I started burning chips for my IROC in Spring of '08 (IIRC) and when I sold the car last July I was still fiddling with the tune on it.
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 12:22 pm    Post subject: |   |
				| the reason i need ur car is to plug in the computer and see if all sensors etc. are working and also to log actual running conditions,.
 i think u can burn a chip in a few hours that will get u close enough to run car as a daily driver ..
 that said , can u please provide specific details about ur engine set up.
 what ecm ?? current chip if u know. weight of car, cam, compression, tpi upgrades?? injector size, TB size, porting?? type of heads, headers??
 does the car run??   i am about 30 miles from u all highway.
 let me know info and we will go from there.
 Mike
		| Back to top |  |
		| Al Hasse Member
 1992  Chevrolet  Camaro RS
				|  Posted: Sun May 30, 2010 12:48 pm    Post subject: |   |
				| IIRC, he now has a TPI setup.  He'll need an adapter to piggyback the new (modified) chip with the stock chip - maybe something like this
 http://www.moates.net/product_info.php?cPath=64&products_id=32
 If need be, I've got the Burn-1 and software from Moates, I'll let you borrow it.  It's Windows based instead of DOS, but if you need to re-learn...
 I'm going to pull the trigger in a couple of weeks and get RBob's EBL Flash unit and won't need the Burn-1 afterward.
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 1:27 pm    Post subject: |   |
				| Is he running the 730 ecm, if so i think the memcal has the EPROM in a socket, and i have several E&EEProm . yes its much easier to use a Moates zif adapter, i have one.....
 Al would like to get together some time, i am now retired and was ET1(SS)... fun times, back then i went for lunch on base to the strip bar and we .......... u get it...
  i would be interested in ur burner... anyway. we need to get that 91SS running,
 later
 Mike
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sun May 30, 2010 1:52 pm    Post subject: |   |
				|  	  | MrMike98 wrote: |  	  | Al would like to get together some time, i am now retired and was ET1(SS)... fun times, back then i went for lunch on base to the strip bar and we .......... u get it...  |
 Could be fun, I was also ET1(SS), worked in the Nav Center.  I'm normally home after 6:30 during the week and free most weekends.  Name a place and we'll see if we can meet up.
 I never did quite get the knack of using the burner, still learning.  Part of it is the new 512 chips that take some special addressing to get to work (256 chips aren't available any more).
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 2:17 pm    Post subject: |   |
				| its a good thing i bought a few extra 29C256....i also have a few original eproms if 91RS comes over so i can look at his car, U are welcome to join the fun..
 i live near the fairgrounds outside silverdale..more to come on this..
 do u know what he has in his motor? trying to find a suitable BIN to start with.
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 30, 2010 2:25 pm    Post subject: |   |
				| You'll need a MAP 305 .bin for an auto car.
 He's running a carb cam in the engine, so you'll have your work cut out for you.
 *Edit: I believe this is the cam, you'll have to get confirmation from Luke on that though:
 http://www.summitracing.com/parts/SUM-K1101/
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 2:41 pm    Post subject: |   |
				| well as long as its TPI and a 730 ECM then a few tweaks to a 350BIN and u have a 305....if i have the car and can datalog all the better. like i said it will be a learning experance for all..
 hey am i going to need to stock up on donuts
		| Back to top |  |
		| Al Hasse Member
				|  Posted: Sun May 30, 2010 2:44 pm    Post subject: |   |
				|  	  | MrMike98 wrote: |  	  | i live near the fairgrounds outside silverdale..more to come on this.. |
 Not far from me at all.  I'm up in the Illahee area off Trenton and Sylvan Way.
		| Back to top |  |
		| 91camaro_rs Member
				|  Posted: Sun May 30, 2010 6:35 pm    Post subject: |   |
				| my car runs but will not drive, so only way to get it to your place would be to have it towed...
 and yes aaron that is the cam that i have
 would the knock sensor have anything to do with the timing issues?? cause i am currently using the knock sensor that was in the block already from 1985....would a new one fix that? 2 days ago it threw two codes the ESC code and the knock sensor code
 is there a way were we could remotley tune it to get it driveable and then i could drive it to your house and have it tuned with the car
		| Back to top |  |
		| aaron_sK Member
				|  Posted: Sun May 30, 2010 6:39 pm    Post subject: |   |
				| Knock sensors rarely go bad, and are somewhat expensive. Wipe codes and see if it can be recreated. If it's throwing an EST code, then you probably haven't wiped since you last set the timing.  |  |
		| Back to top |  |
		| MrMike98 Member
				|  Posted: Sun May 30, 2010 6:40 pm    Post subject: |   |
				| Yes a bad Knock sensor would make car updrivable... there are 2 sensors 1 for a 305 and 1 for a 350, make sure u have the correct one.
 in order to do anything with the chip u must have the engine in good machanical shape and have all the coorect sensors working properly--then u have a chance to tune.....
 do u have a 730 ECM?
 later
		| Back to top |  |
