Posted: Thu May 27, 2010 5:32 am Post subject: |
| aaron_sK wrote: | | Alphius wrote: | Black zip ties. |
Heh. Trick with zipties on plug wires is knowing how to do it. Especially on a V8 since you don't want pairs tied together. You need to make a linked chain out of the ties so that every other tie has a wire through it. This will give a good grip on the wire, and keep the wires apart. |
Aaron is an uppity redneck. He zip ties his wires together in some special order or something.
Mine are zip tied together right after the header tubes to keep them from burning like Rodney's and everyone else's, then zip tied together in whatever order makes them look nicest over the valvecovers up to the distributor.
Black zip ties. Cut the extra off underneath so the zipper is under the wires and looks nicer.
Or hit the junkyard and snatch as many as you can find, or buy a cheap set of clips from somewhere. _________________ 84 Camaro Z28 - LS1/T56
Posted: Thu May 27, 2010 6:34 am Post subject: |
Cause fords were so weak you move the wires around and pistons got broken!  |
Spikeophant Member
Joined: 12 Mar 2010 Posts: 164 Location: Bend, Oregon
1986 Chevrolet Camaro IROC-Z
Posted: Thu May 27, 2010 7:39 am Post subject: |
| aaron_sK wrote: |
If you want to throw money at the problem (and face it, you do, because you restored a Dodge Dart) Taylor makes a very nice set |
Damn, you totally got my number. I'll be picking up a set of clips shortly.... _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Posted: Thu May 27, 2010 8:01 am Post subject: |
| aaron_sK wrote: | Man, must be all that crack I smoke making me think of stuff everybody else already freakin' knows  |
Just yankin' your chain man. No hard feelings. Should've qualified my post and said that you're actually right, but I like making fun of you too.
| chevymad wrote: | Cause fords were so weak you move the wires around and pistons got broken!  |
Heh.
| Spikeophant wrote: | | Damn, you totally got my number. I'll be picking up a set of clips shortly.... |
Good plan. Those are nice clips. If you want to be less redneck than us, you're on the right track. While we're having a discussion of how to effectively zip tie spark plug wires together you're off doing it the right way in the first place.  _________________ 84 Camaro Z28 - LS1/T56
Spikeophant Member
Posted: Thu May 27, 2010 8:32 am Post subject: |
I really like a nice, clean engine bay. While I'm at this, I'm going to clean up my wiring harness, remove things I don't need, etc, so it will be as uncluttered as possible. I'm leaving the A/C in it, so it's not going to be too clean though.... _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Spikeophant Member
Posted: Thu May 27, 2010 3:47 pm Post subject: |
Well, I made a completely rookie mistake. Got the intake, Edelbrock Performer, it's much taller than factory. I'm not sure that it's gonna fit... Any suggestions on a new hood? I'll post some pics of the setup I got after I get them up somewhere. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Posted: Thu May 27, 2010 3:55 pm Post subject: |
| Drop-base air cleaner. Just make sure it clears the horn on the inside, and the linkage on the outside. |
Spikeophant Member
Posted: Thu May 27, 2010 4:00 pm Post subject: |
Here it is, just about all I need, just gotta pick up the MSD box now. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Posted: Thu May 27, 2010 6:48 pm Post subject: |
| Spikeophant wrote: | | Well, I made a completely rookie mistake. Got the intake, Edelbrock Performer, it's much taller than factory. I'm not sure that it's gonna fit... Any suggestions on a new hood? I'll post some pics of the setup I got after I get them up somewhere. |
It will fit just fine with a drop base filter. Might actually have to run a spacer between the carb and filter housing to avoid some filter base to carb interference. I know I had to with an Edelcrap, Demon (holley) clears fine though.
For what it's worth a Performer RPM intake is 15/16ths of an inch taller than a regular Performer. |
Posted: Fri May 28, 2010 6:19 am Post subject: |
| Quote: | | Drop-base air cleaner. |
That should solve your clearence issues. Hell, I have an Airgap and holley and I don't even have a a drop base air cleaner, and I can still get my hood shut. _________________
Posted: Fri May 28, 2010 6:21 am Post subject: |
| don't you have a lawn mower air cleaner? |
Posted: Fri May 28, 2010 6:28 am Post subject: |
| Dewey316 wrote: | | don't you have a lawn mower air cleaner? |
I prefer the term "tri-power" air cleaner.....
Spikeophant Member
I'm definately going to have to swap mine out, I already have issues. I think I'll pull all the insulation out from under the hood, that will give me a bit more clearance. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
IROCDave Member
Posted: Fri May 28, 2010 1:41 pm Post subject: |
Oh BS. You just wanted to show off more pics of that tight intake, and crazy divorced throttle bracketry.  |
Spikeophant Member
Posted: Wed Jun 02, 2010 8:00 am Post subject: |
Well, I think I'm going to do the swap without the msd box to start, when I sell my truck, pick up the box with the money leftover from buying the '67. I'm got beat by a mustang the other day, can't let that happen again.... _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
