MSD 6AL swap
Goto page Previous  1, 2
PostPosted: Thu May 27, 2010 5:32 am    Post subject: Reply with quote
Alphius wrote:
Black zip ties. Razz
Heh. Trick with zipties on plug wires is knowing how to do it. Especially on a V8 since you don't want pairs tied together. You need to make a linked chain out of the ties so that every other tie has a wire through it. This will give a good grip on the wire, and keep the wires apart.
Aaron is an uppity redneck. He zip ties his wires together in some special order or something.
Mine are zip tied together right after the header tubes to keep them from burning like Rodney's and everyone else's, then zip tied together in whatever order makes them look nicest over the valvecovers up to the distributor.
Black zip ties. Cut the extra off underneath so the zipper is under the wires and looks nicer.
Or hit the junkyard and snatch as many as you can find, or buy a cheap set of clips from somewhere.
PostPosted: Thu May 27, 2010 6:13 am    Post subject: Reply with quote
Man, must be all that crack I smoke making me think of stuff everybody else already freakin' knows Shrug
http://www.fordification.com/bumpwiki/index.php?title=Spark_Plug_Wire_Cross-Firing
http://webcache.googleusercontent.com/search?q=cache:MnmuXRqfoY4J:www.jasperengines.com/pdf/SparkPlugCross-FireTB.pdf
Hell, my '95 F150 had a warning sticker from the factory right next to the vacuum and belt diagrams warning about crossfire and giving plug wire routing diagrams.
PostPosted: Thu May 27, 2010 6:34 am    Post subject: Reply with quote
Cause fords were so weak you move the wires around and pistons got broken! Laughing
Spikeophant
1986 Chevrolet Camaro IROC-Z
PostPosted: Thu May 27, 2010 7:39 am    Post subject: Reply with quote
If you want to throw money at the problem (and face it, you do, because you restored a Dodge Dart) Taylor makes a very nice set
Damn, you totally got my number. I'll be picking up a set of clips shortly....
1986 Camaro Z-28 IROC-Z 350 swap
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Thu May 27, 2010 8:01 am    Post subject: Reply with quote
Just yankin' your chain man. No hard feelings. Very Happy Should've qualified my post and said that you're actually right, but I like making fun of you too.
Heh.
Good plan. Those are nice clips. If you want to be less redneck than us, you're on the right track. While we're having a discussion of how to effectively zip tie spark plug wires together you're off doing it the right way in the first place. Razz
Spikeophant
PostPosted: Thu May 27, 2010 8:32 am    Post subject: Reply with quote
I really like a nice, clean engine bay. While I'm at this, I'm going to clean up my wiring harness, remove things I don't need, etc, so it will be as uncluttered as possible. I'm leaving the A/C in it, so it's not going to be too clean though....
Spikeophant
PostPosted: Thu May 27, 2010 3:47 pm    Post subject: Reply with quote
Well, I made a completely rookie mistake. Got the intake, Edelbrock Performer, it's much taller than factory. I'm not sure that it's gonna fit... Any suggestions on a new hood? I'll post some pics of the setup I got after I get them up somewhere.
PostPosted: Thu May 27, 2010 3:55 pm    Post subject: Reply with quote
Drop-base air cleaner. Just make sure it clears the horn on the inside, and the linkage on the outside.
Spikeophant
PostPosted: Thu May 27, 2010 4:00 pm    Post subject: Reply with quote
Here it is, just about all I need, just gotta pick up the MSD box now.
PostPosted: Thu May 27, 2010 6:48 pm    Post subject: Reply with quote
It will fit just fine with a drop base filter. Might actually have to run a spacer between the carb and filter housing to avoid some filter base to carb interference. I know I had to with an Edelcrap, Demon (holley) clears fine though.
For what it's worth a Performer RPM intake is 15/16ths of an inch taller than a regular Performer.
PostPosted: Fri May 28, 2010 6:19 am    Post subject: Reply with quote
That should solve your clearence issues. Hell, I have an Airgap and holley and I don't even have a a drop base air cleaner, and I can still get my hood shut.
PostPosted: Fri May 28, 2010 6:21 am    Post subject: Reply with quote
don't you have a lawn mower air cleaner?
PostPosted: Fri May 28, 2010 6:28 am    Post subject: Reply with quote
Squint
I prefer the term "tri-power" air cleaner.....
Razz
Spikeophant
I'm definately going to have to swap mine out, I already have issues. I think I'll pull all the insulation out from under the hood, that will give me a bit more clearance.
IROCDave
PostPosted: Fri May 28, 2010 12:42 pm    Post subject: Reply with quote
Another vote for zip ties! At a minimum I would route the wires how you like ( secure with zip ties) then add a set of wire seperaters of your choosing.
Couple of pics of my settup with ties. When the plenum is installed you cant really see the wires anyway.
http://i299.photobucket.com/albums/mm295/IROCDAVE/SLP%20T-Ram%20cruise%20control%20bracket/SLPT-Ramcruisecontrolbracket003-1.jpg
http://i299.photobucket.com/albums/mm295/IROCDAVE/2IROCs2008025.jpg
PostPosted: Fri May 28, 2010 1:41 pm    Post subject: Reply with quote
Oh BS. You just wanted to show off more pics of that tight intake, and crazy divorced throttle bracketry. Razz
Spikeophant
PostPosted: Wed Jun 02, 2010 8:00 am    Post subject: Reply with quote
Well, I think I'm going to do the swap without the msd box to start, when I sell my truck, pick up the box with the money leftover from buying the '67. I'm got beat by a mustang the other day, can't let that happen again....
Page 2 of 2
