Need some help
PostPosted: Sun Oct 18, 2009 1:19 am    Post subject: Need some help Reply with quote
So what sensors are identical and swappable between an LB9 and LT1?
PostPosted: Sun Oct 18, 2009 10:57 am    Post subject: Reply with quote
intake air temp and injectors? Distributor is different, MAF is different, o2's are heated narrowband to 94 at least, MAP is custom fit to the intake so has a different port on it. Not sure what you can nab off it.
PostPosted: Sun Oct 18, 2009 12:03 pm    Post subject: Reply with quote
LoL yeah dude. IF you got that whole engine setup, use everything it came with. TPI is a whole other world than LT1. I've heard of people using LT1 Throttle bodies so the IAC and TPS might be the same. There are a couple versions of IACs I've seen so who knows.
PostPosted: Mon Oct 19, 2009 7:09 am    Post subject: Reply with quote
I think you're right on that one. The plugs might be different but the sensors might operate the same. What exactly are you trying to accomplish?
PostPosted: Mon Oct 19, 2009 3:00 pm    Post subject: Reply with quote
Well I have a bunch of brand new sensors on my LB9 and would hate to have them go to waste when I put my LT1 in.
PostPosted: Mon Oct 19, 2009 3:08 pm    Post subject: Reply with quote
Laughing Sometimes you just have to eat the little things like that. Before I dropped the motor in mine I had replaced about every sensor on my bird, tps, iac, map, o/p, iat, cts, o2 all within a year of the swap. Oh well.
