Posted: Sun Oct 18, 2009 1:19 am Post subject: Need some help |
So what sensors are identical and swappable between an LB9 and LT1? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sun Oct 18, 2009 10:57 am Post subject: |
intake air temp and injectors? Distributor is different, MAF is different, o2's are heated narrowband to 94 at least, MAP is custom fit to the intake so has a different port on it. Not sure what you can nab off it. _________________ E30
Posted: Sun Oct 18, 2009 12:03 pm Post subject: |
LoL yeah dude. IF you got that whole engine setup, use everything it came with. TPI is a whole other world than LT1. I've heard of people using LT1 Throttle bodies so the IAC and TPS might be the same. There are a couple versions of IACs I've seen so who knows. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 19, 2009 7:09 am Post subject: |
| I think you're right on that one. The plugs might be different but the sensors might operate the same. What exactly are you trying to accomplish? |
Posted: Mon Oct 19, 2009 3:00 pm Post subject: |
Well I have a bunch of brand new sensors on my LB9 and would hate to have them go to waste when I put my LT1 in. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Oct 19, 2009 3:08 pm Post subject: |
| DBL_TKE wrote: | | Well I have a bunch of brand new sensors on my LB9 and would hate to have them go to waste when I put my LT1 in. |
Sometimes you just have to eat the little things like that. Before I dropped the motor in mine I had replaced about every sensor on my bird, tps, iac, map, o/p, iat, cts, o2 all within a year of the swap. Oh well. |
