TurdGen1989 Member
Posted: Sat Sep 19, 2009 7:35 pm Post subject: |
Hope you're getting new tires. 235 on a 7" rim sounds a little fishy to me. He might just be wrong though, since he's got them listed as '95 Camaro rims, I don't think he's to good with numbers.  |
Posted: Sat Sep 19, 2009 7:39 pm Post subject: |
Those look just like the ones I sold to Aaron, but I painted them black to cover up the faded red Those would look real good if you were able to polish them to a mirror finish, alot of work, but doable  _________________ 92 Camaro
| Whats fishy bout the size? I've got 215s on the front and 275's on the rear of the 2nd gen, both on 7" rims. |
Posted: Sat Sep 19, 2009 8:03 pm Post subject: |
Do you get a lot of sidewall movement with a 275, Brandon?
I always see guys try and shove a wider tire on, and it just ends up squishy and bulging out. |
Posted: Sat Sep 19, 2009 8:15 pm Post subject: |
| A 275 is about right for an 8" wheel. On my 10" wheels they're a bit small. It is large for 7" but works fine. |
TurdGen1989 Member
Posted: Sat Sep 19, 2009 8:47 pm Post subject: |
lol i know his wife and him don't sound like their all there ... but who cares new wheels FTW! .. as far as polishing them I'm prolly just gonna paint them black ... _________________ Phil.
GMC High Sierra
Posted: Sat Sep 19, 2009 10:36 pm Post subject: |
I run 245's on my 16x7's. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
TurdGen1989 Member
Posted: Sun Sep 20, 2009 8:31 am Post subject: |
that was what i was thinking to do. what kind of paint did you use? _________________ Phil.
GMC High Sierra
Posted: Sun Sep 20, 2009 9:27 am Post subject: |
| After they were stripped, I used a self-etching primer, then a couple of coats of caliper paint (Duplicolor, I think I used), followed by a clear coat. |
TurdGen1989 Member
Posted: Sun Sep 20, 2009 2:10 pm Post subject: |
lol well the tires were 235 and they barely fit in the back so when i get tires for the front ones i need like 215 or like 225 cuz 235s dont fit at all im to low _________________ Phil.
GMC High Sierra
Posted: Sun Sep 20, 2009 2:41 pm Post subject: |
| Huh??? The wheel must not be centered well. I have a lowered car with 275/40 on 17x9 rims and I have tons of extra room to the inside. In fact, I wish I had 18x10 wheels in the back. Mine look skinny from a rear view. |
Posted: Sun Sep 20, 2009 6:46 pm Post subject: |
| How much are you lowered? I had 245's on 16x8 IROC rims and they fit fine lowered about two inches off the base-model. |
TurdGen1989 Member
Posted: Sun Sep 20, 2009 11:34 pm Post subject: |
lol idk i need to measure but i dont think they'll fit in the front im gonna mount the two that has tires on em on the front and see _________________ Phil.
GMC High Sierra
TurdGen1989 Member
Posted: Thu Sep 24, 2009 9:53 pm Post subject: |
ok well i got them mounted up turns out it was so low becuase of the 14's that were on it so i went with 235 60 15 up front and 245 60's in the rear looks so much better than it did ... ill try and post some pics tomorrow! _________________ Phil.
GMC High Sierra
Posted: Thu Sep 24, 2009 10:12 pm Post subject: |
Psh, too low . I've yet to run into any real problems at my 3" lower than stock ride height. I was running 285's all around as well. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Sep 24, 2009 10:35 pm Post subject: |
| DBL_TKE wrote: | Psh, too low . I've yet to run into any real problems at my 3" lower than stock ride height. I was running 285's all around as well. |
Psh, I've heard stories of guys running 3" lower than stock ride height on 3 wheels. Now that's badass!!  |
TurdGen1989 Member
Posted: Fri Sep 25, 2009 12:00 pm Post subject: |
| rjmcgee wrote: |
x2!!! _________________ Phil.
GMC High Sierra
