laegion Member
Posted: Sat Oct 23, 2004 9:14 pm Post subject: anyone here play guitar? |
I just got a squire stratocaster about a month ago and I'm going nuts I keep snapping High E strings 3 in less than a month, and I hardly play. it's really beginning to Torque me off. _________________ 95 vw jetta gl
currently looking for a cheap ninja 250 or 500 or comperable 2cyl sportbike. |
Posted: Sat Oct 23, 2004 9:41 pm Post subject: |
Where is the string breaking? If its breaking at the nut, check for a burr or knick in the nut. Are you tuned to A 440 standard tuning? Over tensioning of the E will cause it to break easily. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
laegion Member
Posted: Sat Oct 23, 2004 10:11 pm Post subject: |
standard tuning. and it's breaking at the saddle. I think I figured out why, the saddle is worn and seems to have a "channel" worn in where the string lays. or maybe I just dont' have the saddle adjusted right, I just adjusted it so that the string doesn't catch on the block, because I figured that would cause it to break. _________________ 95 vw jetta gl
Posted: Sun Oct 24, 2004 12:30 pm Post subject: |
You might also try going to a diffrent guage string. I can't play on 9 guage, because I always break that string..... 11's for me
BTW, here is my setup.
laegion Member
Posted: Sun Oct 24, 2004 2:36 pm Post subject: |
| Dewey316 wrote: | You might also try going to a diffrent guage string. I can't play on 9 guage, because I always break that string..... 11's for me
yeah I was thinking of that too, I don't remember what guage the high e's I have are, but they are ernie ball strings. i'll just have to look at the package when i'm at home. but the strings did seem a little bit thin when I put them on when i got the guitar. but it's been so long since I've had a guitar I thought that I must have been imagining it. maybe now thinking about it. maybe I wasn't imagining it? I almost never broke strings on my old guitar. I think I broke two in like 3 years.
Sweet setup!
I only have a anniversary addition squire strat that's metallic red with pearlized pick guard. it's real nice, but I only have a little amp and no pedals. but I'm just learning to play electric so, it's ok for now. _________________ 95 vw jetta gl
Posted: Sun Oct 24, 2004 5:18 pm Post subject: |
| I used to break the low and high E stings ALL the time when I had earnie ball stings, and I tried lighter and powerslinky and still broke them. Switch to D'addario and havn't broken one since, and it's been 2 years since I switched. |
laegion Member
Posted: Mon Oct 25, 2004 12:44 am Post subject: |
I looked at the package and it's a 10 guage string.
hmmm.... well I'll try a 11 guage first if that doesn't work then i'll probably switch brands. _________________ 95 vw jetta gl
Posted: Mon Oct 25, 2004 3:22 am Post subject: |
| I would switch to D'addario anyway. They are my string of choice also. Great strings, and they seem to hold their tune much better than others. |
PonchoTA Member
Posted: Mon Oct 25, 2004 4:45 am Post subject: |
| Dewey316 wrote: | | I would switch to D'addario anyway. They are my string of choice also. Great strings, and they seem to hold their tune much better than others. |
D'addario!!
(I'll reserve my comment to change the pickups to Dimarzio too, I guess!) _________________ Paully |
Posted: Mon Oct 25, 2004 4:51 am Post subject: |
| What you can't see in my pictures, is that both pick-ups in the Ibanez are DiMarzio. I was pretty happy with the Semore-Dunkin "Screamin' Demon" that I had before the DM's, but it was alot more pick-up than I needed, and more than a little 'Harmonic Happy' |
PonchoTA Member
Posted: Mon Oct 25, 2004 11:24 am Post subject: |
| Dewey316 wrote: | | What you can't see in my pictures, is that both pick-ups in the Ibanez are DiMarzio. I was pretty happy with the Semore-Dunkin "Screamin' Demon" that I had before the DM's, but it was alot more pick-up than I needed, and more than a little 'Harmonic Happy' |
I didn't think Ibanez put anything BUT DiMarzio pickups in, unless you specifically ask otherwise, or put it in yourself! I've got a custom build solid body that has a pair of Strat single coils with a Carvin M-22 at the neck instead of the bridge, sounds sweet!!! (Just wish I played better!!!)
P _________________ Paully |
Posted: Mon Oct 25, 2004 11:40 am Post subject: |
Mine are not your average stocker DM's
The guitar is a Custom Shop 520 with the QS wood option. Its got a tone-zone (375mV output ) and an air norton pickup. I had the screamin' demon on there, but that would find harmonics I didn't even know excisted. |
laegion Member
Posted: Mon Oct 25, 2004 12:42 pm Post subject: |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed Oct 27, 2004 7:12 am Post subject: |
Looks like the crew has more axes than Lynard Skynard.
BTW I have a Rocktron practice amp also, you can not belive the tone those amps make!
Here is my Jackson with ear cleaner:
http://community.webshots.com/photo/206644024/206644208lqlSxq
Just a note I can get bottom line prices on gear, for example the VTone GMX212 shown above lists for $369, I got it for $180, tons of features for the price:
Analog modeling
2x50W power
2 - 12" Jensen speaker
2 channels
27 modeled sounds
24-bit effects processor with chorus, flanging, phasing, rotary, auto-wah, echo, delay, compressor, and combinations
FXT function
Dynamizer signal enhancement circuitry
Tuner
MIDI control
I was surfing on Comcast the other day, they have Guitar lessons in On Demand. Dig It
Rock On !
Don
[/url] _________________
Posted: Wed Oct 27, 2004 7:20 am Post subject: |
Don,
What specific brands can you get great deals on? i'm always in the market.
edit: I'll add, if you can get a great deal on a EB Axis... I would be VERY interested. |
85 T/A WS6 Member
Posted: Wed Oct 27, 2004 8:00 am Post subject: |
Hey D-316, whats an EB Axis ?
My freind is a dealer for most brands so with some specifics I can ask him for a quote. |
85 T/A WS6 Member
Posted: Wed Oct 27, 2004 8:25 am Post subject: |
Got it, I ll get back to you soon.  |
Posted: Wed Oct 27, 2004 6:25 pm Post subject: |
I'm a bass player, but my rig consists of:
QSC800 800watt power amp
Line6 Bass Pod Pro
Juice Goose 'Zilla 8 power conditioner
Samson Wireless
Carvin 4x10 cab
Carvin 1x15 cab
And my guitars:
Carvin LB75 5 string bass
Ibanez Soundgear SR305 5 string bass
Here is me rocking out at The Central Tavern in Seattle:
laegion Member
Posted: Wed Oct 27, 2004 9:08 pm Post subject: |
my head hurts!
there is way too much to know about this stuff, and I have only begun to learn. _________________ 95 vw jetta gl
