kurfbird Member
Posted: Sun May 31, 2009 7:26 pm Post subject: 2.8 motor FREE |
Okay this motor came from a 89 Camaro. It has two broken bolts that bolt up to the trans. Probably easly removed. Comes with intake. Needs a new flywheel. Other one is cracked.
I took the injectors distributor wires etc. Still has the water pump. Bring your truck and you can use my cherry picker. It going with the junk car as soon as the yard comes to get it _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
J-Dog-III Member
Posted: Tue Jun 02, 2009 8:47 pm Post subject: |
| might be interested, do you know the mileage, if it ran etc? |
kurfbird Member
Posted: Tue Jun 02, 2009 8:55 pm Post subject: Its gone |
Sorry the junk man came today. So its now crushed. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012 Member
Posted: Tue Jun 02, 2009 9:07 pm Post subject: |
The 3.1 isn't getting the same fate? I want to be able to check it out and determine if I want it (I most likely will). _________________
kurfbird Member
Posted: Tue Jun 02, 2009 9:40 pm Post subject: 3.1 is being kept for sale |
Just to many things wrong with the 2.8 so it went with the 91 camaro I parted out. ALos used for parts for my 91 toy _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
