2.8 motor FREE
kurfbird
PostPosted: Sun May 31, 2009 7:26 pm    Post subject: 2.8 motor FREE Reply with quote
Okay this motor came from a 89 Camaro. It has two broken bolts that bolt up to the trans. Probably easly removed. Comes with intake. Needs a new flywheel. Other one is cracked.
I took the injectors distributor wires etc. Still has the water pump. Bring your truck and you can use my cherry picker. It going with the junk car as soon as the yard comes to get it
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
J-Dog-III
PostPosted: Tue Jun 02, 2009 8:47 pm    Post subject: Reply with quote
might be interested, do you know the mileage, if it ran etc?
kurfbird
PostPosted: Tue Jun 02, 2009 8:55 pm    Post subject: Its gone Reply with quote
Sorry the junk man came today. So its now crushed.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
d00012
PostPosted: Tue Jun 02, 2009 9:07 pm    Post subject: Reply with quote
The 3.1 isn't getting the same fate? I want to be able to check it out and determine if I want it (I most likely will).
kurfbird
PostPosted: Tue Jun 02, 2009 9:40 pm    Post subject: 3.1 is being kept for sale Reply with quote
Just to many things wrong with the 2.8 so it went with the 91 camaro I parted out. ALos used for parts for my 91 toy
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
