corey davidson Member
1986 Chevrolet Camaro
Posted: Thu Mar 26, 2009 3:47 pm Post subject: okey dokey |
so got her runnin now im movin on to my stereo i got feed go in to the amp but the subs not workin everhting is hooked up right i think any ideas  _________________ real men are covered in oil and grease |
Posted: Thu Mar 26, 2009 3:55 pm Post subject: |
Are you using the RCA output for the subs, or a combo of the rear-channel output?
Most aftermarket stereo's, you have to enable the sub-channel output through the RCA's, before it will start sending a signal. |
HONDASLAYER Member
Posted: Thu Mar 26, 2009 5:42 pm Post subject: |
does your deck have an internal sub controler? is it turned on? recheck your amp ground maybe... _________________
83sbcz28 New Member
Posted: Thu Mar 26, 2009 5:44 pm Post subject: |
| yep just what they said. What deck do you got? |
Posted: Thu Mar 26, 2009 6:24 pm Post subject: |
jvc kd-s33 it has it sub shut off i just dont no were  _________________ real men are covered in oil and grease |
Posted: Thu Mar 26, 2009 6:26 pm Post subject: |
Time to find the owners manual. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 26, 2009 6:41 pm Post subject: |
http://books.jvcservice.com/Download/395344703/GET0401-001A.pdf
For reference....
Basicly, you need to press and hold the "SEL" button, then turn the adjuster ring until you get to "L/O Mode". Set "L/O Mode" to "Woofer". That will set the rear RCA outputs into sub-woofer outs.
Once that is done, you need to set the woofer output level. To do that, just press "SEL" quickly, that will bring up another menu with your sound options. You should now have a "SUB.W" option. You can turn the adjuster to set that.
--John |
