okey dokey
corey davidson
1986 Chevrolet Camaro
PostPosted: Thu Mar 26, 2009 3:47 pm    Post subject: okey dokey Reply with quote
so got her runnin now im movin on to my stereo i got feed go in to the amp but the subs not workin everhting is hooked up right i think any ideas Question
real men are covered in oil and grease
PostPosted: Thu Mar 26, 2009 3:55 pm    Post subject: Reply with quote
Are you using the RCA output for the subs, or a combo of the rear-channel output?
Most aftermarket stereo's, you have to enable the sub-channel output through the RCA's, before it will start sending a signal.
HONDASLAYER
PostPosted: Thu Mar 26, 2009 5:42 pm    Post subject: Reply with quote
does your deck have an internal sub controler? is it turned on? recheck your amp ground maybe...
<div>Quizzes Girls Games</div>
83sbcz28
New Member
PostPosted: Thu Mar 26, 2009 5:44 pm    Post subject: Reply with quote
yep just what they said. What deck do you got?
corey davidson
PostPosted: Thu Mar 26, 2009 6:24 pm    Post subject: Reply with quote
jvc kd-s33 it has it sub shut off i just dont no were Embarassed
PostPosted: Thu Mar 26, 2009 6:26 pm    Post subject: Reply with quote
Time to find the owners manual.
PostPosted: Thu Mar 26, 2009 6:41 pm    Post subject: Reply with quote
http://books.jvcservice.com/Download/395344703/GET0401-001A.pdf
For reference....
Basicly, you need to press and hold the "SEL" button, then turn the adjuster ring until you get to "L/O Mode". Set "L/O Mode" to "Woofer". That will set the rear RCA outputs into sub-woofer outs.
Once that is done, you need to set the woofer output level. To do that, just press "SEL" quickly, that will bring up another menu with your sound options. You should now have a "SUB.W" option. You can turn the adjuster to set that.
--John
