9-bolt Borg Warner, how to tell if Posi?
Magman
1990 Chevrolet Camaro IROC-Z
PostPosted: Wed Nov 12, 2008 7:56 pm    Post subject: 9-bolt Borg Warner, how to tell if Posi? Reply with quote
How do I determine if a 9-bolt rear is Posi or not? This is unfamiliar territory for me. I can pop the cover tomorrow and post a pic of what it looks like inside, but I'm unsure of what I should be looking for? Thanks!
1990 IROC-Z, 383 HSR, 3.70 9-Bolt
383 RWHP / 372 TQ
11.78 @ 115 w/1.59 60' (8-18-2012)
PostPosted: Wed Nov 12, 2008 9:02 pm    Post subject: Reply with quote
Best way it to just turn one axle and see which way the other axle turns.
Same direction = working posi
Opposite directions = non posi/worn out posi
PostPosted: Wed Nov 12, 2008 10:10 pm    Post subject: Reply with quote
What Paul says on the 9bolt. Now if it was a 10 bolt you'd have to worry about the Zexel/torsens which act like a non posi.
Magman
PostPosted: Thu Nov 13, 2008 5:44 am    Post subject: Reply with quote
OK, thanks. I'll give that a shot and see what happens.
383 RWHP / 372 TQ
PostPosted: Thu Nov 13, 2008 12:17 pm    Post subject: Reply with quote
lucky for you almost all of the 9 bolt rears are "performance" optioned with at least an ok gear ratio, and posi. most are 3.27:1 or 3.40(ish):1.
Very Happy australia is cool.
PostPosted: Thu Nov 13, 2008 5:33 pm    Post subject: Reply with quote
Hmm never seen anything but 3.27 and 3.70s
PostPosted: Thu Nov 13, 2008 6:02 pm    Post subject: Reply with quote
3.70.. I knew it was something big. my mistake on the 3.40ish.
PostPosted: Thu Nov 13, 2008 6:23 pm    Post subject: Reply with quote
9 bolt ratios
2.77
3.27
3.45
3.70
I have to check the ratio on the 9 bolt in this this 87 GTA I have. As long as it has a 3 series carrier I'm gonna rebuild it with a set of 3.73's for my car. I think Mike as proved the 9 bolt is a good upgrade over the 10 bolt.
Magman
PostPosted: Thu Nov 13, 2008 9:03 pm    Post subject: Reply with quote
Yeah, that's what everyone says. The 9-bolt is superior. I had no luck turning one side of this one tonight though. The right brake seems to be locked up. I'll have to take the brakes off to check it out. The left side turns freely while the right is locked up by the brake.
I also read the 9-bolts have different axles, 26 spline before 88 and 28 splines after. This rear wasn't stock though, it has "87 Camaro" written on it in yellow marker. Typical marker used in wrecking yards Sad
383 RWHP / 372 TQ
PostPosted: Fri Nov 14, 2008 12:31 am    Post subject: Reply with quote
if you can turn one wheel freely while the other is locked up, then its not a posi, at least not a working one.
What kind of brakes? are they the aluminum PBR's?
Magman
PostPosted: Fri Nov 14, 2008 6:01 am    Post subject: Reply with quote
No, non-PBR. This things a paper weight... 2.77 gears, non PBR, unitrack, it doesn't have anything going for it!
383 RWHP / 372 TQ
PostPosted: Fri Nov 14, 2008 5:36 pm    Post subject: Reply with quote
Ew.
redlava
PostPosted: Sun Nov 16, 2008 11:45 am    Post subject: Reply with quote
pull it apart and take a look at the posi cones to see if they are completely worn out or if it possible to shim
Magman
PostPosted: Sun Nov 16, 2008 2:06 pm    Post subject: Reply with quote
Yeah, I was thinking of pulling it apart to see what it's made of. Plan to keep the shims as spares for the 3.45 9-bolt I have waiting to be rebuilt. More and more projects just keep piling up...
383 RWHP / 372 TQ
