pre '86 block with '86 tranny
PostPosted: Mon Aug 18, 2008 6:51 pm    Post subject: pre '86 block with '86 tranny Reply with quote
I just purchased a long block 350 for my '86 T/A. I believe that '86 was the first year for the 1 piece rear main seal. This block is older and has a 2 piece rear main seal. Do I need an adapter to run my '86 700R4? I think I had heard that before... Confused
PostPosted: Mon Aug 18, 2008 7:14 pm    Post subject: Reply with quote
Tranny is the same, but you may need a differant flex plate depending if your 86 was 1 piece or 2 piece.
PostPosted: Mon Aug 18, 2008 8:06 pm    Post subject: Reply with quote
'86 was hit and miss. '87 was standard as 1 piece rear.
You'll have to look. Flexplates are different because of the different crank. Just get the proper tooth flexplate for the old style (2 piece) and you're good to go. Everything else bolts up perfect.
PostPosted: Mon Aug 18, 2008 10:54 pm    Post subject: Reply with quote
Sweet! I got the flex plate with the engine so I should be good to go, right? Smile
PostPosted: Tue Aug 19, 2008 6:26 am    Post subject: Reply with quote
Yep.
PostPosted: Tue Aug 19, 2008 7:51 pm    Post subject: Reply with quote
guess i didn't see this post... Embarassed
PostPosted: Tue Aug 19, 2008 9:34 pm    Post subject: Reply with quote
Thats why I called to tell you about it Doofus! Very Happy
PostPosted: Tue Aug 19, 2008 10:02 pm    Post subject: Reply with quote
lol...i'm talking bout the post i made on the back porch... Laughing
