Posted: Wed Jul 30, 2008 9:49 pm Post subject: Door Hinge Problems |
So i'm having some problems with these door hinge pins. I was able to remove the spring and smash out the pin, but the bushings are sandwiched in the hinge. Should i be taking the whole door off?
Posted: Wed Jul 30, 2008 10:04 pm Post subject: |
I ended up removing the 3 bolts on the upper hinge also to make things easier. I had a friend and a floor jack to support the door while removing the bushings. With those 3 bolts undone, the door is essentially disconnected from the body and will fall off if not supported. Tony has a pic where he used an engine hoist with straps to hold the door up. I forget the part number offhand, but the replacement pin listed in the HELP! section at the parts stores for our cars is too small - I've posted it before _________________ 92 Camaro
Posted: Thu Jul 31, 2008 12:22 am Post subject: |
I actually picked up a replacement pin at the parts store and have been meaning to install it. I can give you the part number tomorrow if you need it. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
jakemk8706 Member
Posted: Thu Jul 31, 2008 12:30 am Post subject: |
get the sledge hammer and pound it into submission.
or, try cursing at it until your face turns blue or the neighbors call the 5-0 _________________ gas brake dip dip |
Posted: Thu Jul 31, 2008 6:46 am Post subject: |
| I found the part numbers in an older post of mine. The pin & bushings are in the "HELP!" section, the ones they sell for our cars is part # 38402. That was too small for my car and I had to use the oversized kit, part # 38407. |
Posted: Thu Jul 31, 2008 10:52 am Post subject: |
 _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
Posted: Thu Jul 31, 2008 11:07 am Post subject: |
| Smart way to do that, but I'm sure the neighbors and passerbys were looking like WTF?!?!?! |
