More Head Questions
PostPosted: Mon Jun 09, 2008 6:56 am    Post subject: More Head Questions Reply with quote
ok, so the state wide swapmeet, carshow, etc is this coming weekend. Its mostly for old antiques, but you can find about anything here.
I have "810" swirlport heads on my motor. What would be some upgrades.....
The vortecs, but what casting #'s?
Then what are real L98 heads?
Vette aluminums which are "183" correct?
Any other goodies I should keep my eyes open for?
Split 1.5/1.6 roller rockers?
vette valve covers?
16" s10 wheels
New Runners?
PostPosted: Mon Jun 09, 2008 2:08 pm    Post subject: Reply with quote
Vortecs or L98's would be a good way to go.
If you do vortecs, you'll have to change your intake manifold.
"906" seems to be a pretty popular Vortec casting, with desirable (64cc) combustion chambers and a 170cc intake.
PostPosted: Tue Jun 10, 2008 5:37 am    Post subject: Reply with quote
yea, I knew the vortecs needed a different base. As well, cant run an egr with them.
PostPosted: Tue Jun 10, 2008 6:48 am    Post subject: Reply with quote
Sure you can. You do it Vette style and run an external stand alone.
PostPosted: Tue Jun 10, 2008 9:22 am    Post subject: Reply with quote
doesnt the vette plub it into the base of the intake, just in a different area then the camaros?
found some part numbers here:
Vortec "062"
Vortec "906"
fastburn "712","713"
L98 vette "113"
L98 fbody "083"
PostPosted: Tue Jun 10, 2008 11:18 am    Post subject: Reply with quote
Edelbrock makes a vortec base for the camaro TPI intake too. You could then run the intake you have with whatever heads you wanted if you had one of those.
PostPosted: Tue Jun 10, 2008 11:35 am    Post subject: Reply with quote
Yea, I know the make the intake and its expensive. But the discussion is about the EGR. Since I'm not sure where/when I move, the state may require smog testing. Doubt the car will pass Laughing , but atleast I give it a try.
PostPosted: Fri Jun 20, 2008 6:17 pm    Post subject: Reply with quote
Bringing that back to the top with another question.
Why does the vette have the external tube. Do the 113 aluminum heads not have the exhaust passage port?
