Posted: Mon Jun 09, 2008 6:56 am Post subject: More Head Questions |
ok, so the state wide swapmeet, carshow, etc is this coming weekend. Its mostly for old antiques, but you can find about anything here.
I have "810" swirlport heads on my motor. What would be some upgrades.....
The vortecs, but what casting #'s?
Then what are real L98 heads?
Vette aluminums which are "183" correct?
Any other goodies I should keep my eyes open for?
Split 1.5/1.6 roller rockers?
vette valve covers?
16" s10 wheels
New Runners? _________________ 2008 GMC Z71
Posted: Mon Jun 09, 2008 2:08 pm Post subject: |
Vortecs or L98's would be a good way to go.
If you do vortecs, you'll have to change your intake manifold.
"906" seems to be a pretty popular Vortec casting, with desirable (64cc) combustion chambers and a 170cc intake. _________________
Posted: Tue Jun 10, 2008 5:37 am Post subject: |
yea, I knew the vortecs needed a different base. As well, cant run an egr with them. _________________ 2008 GMC Z71
Posted: Tue Jun 10, 2008 6:48 am Post subject: |
| 91RSVert wrote: | | yea, I knew the vortecs needed a different base. As well, cant run an egr with them. |
Sure you can. You do it Vette style and run an external stand alone. |
Posted: Tue Jun 10, 2008 9:22 am Post subject: |
| Twilightoptics wrote: | | 91RSVert wrote: | | yea, I knew the vortecs needed a different base. As well, cant run an egr with them. |
doesnt the vette plub it into the base of the intake, just in a different area then the camaros?
found some part numbers here:
Vortec "062"
Vortec "906"
fastburn "712","713"
L98 vette "113"
L98 fbody "083" _________________ 2008 GMC Z71
Posted: Tue Jun 10, 2008 11:18 am Post subject: |
| Edelbrock makes a vortec base for the camaro TPI intake too. You could then run the intake you have with whatever heads you wanted if you had one of those. |
Posted: Tue Jun 10, 2008 11:35 am Post subject: |
Yea, I know the make the intake and its expensive. But the discussion is about the EGR. Since I'm not sure where/when I move, the state may require smog testing. Doubt the car will pass , but atleast I give it a try. _________________ 2008 GMC Z71
Posted: Fri Jun 20, 2008 6:17 pm Post subject: |
Bringing that back to the top with another question.
Why does the vette have the external tube. Do the 113 aluminum heads not have the exhaust passage port? _________________ 2008 GMC Z71
