cameron7710 Member
Posted: Wed Jun 04, 2008 8:01 pm Post subject: T-5 swap? |
iv been thinking that i would like a manual camaro instead of the boring auto but iv been wondering if its worth the time money or effort.so i just wanted to know what all was involvd in the swap and how hard it is to do.and around how much is it going to cost.or if it would be better to get another thirdgen cause i could always go for 2  _________________
Posted: Wed Jun 04, 2008 8:06 pm Post subject: |
Do eeet!
You'll need the 5-speed trans, bellhousing, crossmember, pedals, shifter, shift plate, clutch, flywheel, hydraulics(master and slave cylinder) and associated bolts. _________________
Posted: Wed Jun 04, 2008 8:10 pm Post subject: |
| And you have to drill a couple of holes. |
Posted: Wed Jun 04, 2008 8:14 pm Post subject: |
| Dewey316 wrote: | | And you have to drill a couple of holes. |
And I believe you need to cut a large square one in the floor for the shifter. _________________ 92 Camaro
cameron7710 Member
Posted: Wed Jun 04, 2008 8:24 pm Post subject: |
ya i think ima go for it when i can get some money put away for the parts plus i think it will be good to swap out the 700r4 caues im sure its getin tired after 288,000 miles its had a good life i think its time for retirment,then what to do about that just as tired 305 _________________
Posted: Wed Jun 04, 2008 8:39 pm Post subject: |
| Al Hasse wrote: | | Dewey316 wrote: | | And you have to drill a couple of holes. |
And I believe you need to cut a large square one in the floor for the shifter. |
Well I just considered those things you "don't need"  |
Posted: Wed Jun 04, 2008 8:59 pm Post subject: |
You don't need a new crossmember. Just buy an energy suspension transmission mount and you should be set.
Its not too tough to do. I'm sure between crew members we might have just about all the parts to do it too! _________________
Posted: Wed Jun 04, 2008 9:11 pm Post subject: |
Don't even need the new tranny mount.
Get a T5 transmission.
Bell housing.
Flywheel.
Clutch
Pilot Bushing.
Clutch Fork.
Throw Out Bearing.
Thirdgen Pedal Assembly.
Clutch Master Cylinder, Slave, Reservoir, Lines.
Shifter.
3 qt's ATF
Netral Safety Switch.
Reverse Swtich (in trans)
Get all that.... Provide beer and be a cool hostess and atleast I'll show up and help ya do it! |
Posted: Wed Jun 04, 2008 9:21 pm Post subject: |
Paul, if he can't even get a drivers liscense yet, I don't think they'll sell him beer.
That said, if he doesn't mind everyone coming over and getting drunk, I'm sure we can get it together fast. |
Posted: Wed Jun 04, 2008 9:25 pm Post subject: |
| aaron_sK wrote: | Paul, if he can't even get a drivers liscense yet, I don't think they'll sell him beer.
Small technicality. |
cameron7710 Member
Posted: Wed Jun 04, 2008 9:32 pm Post subject: |
ok thanks for the help with the part list every one ill let u guy know when i get every think but that could be for a while do to me being broke and not having a job  _________________
Posted: Wed Jun 04, 2008 9:36 pm Post subject: |
You're off for the summer, so get to it. We need you to earn some money fast so we can get drunk.  |
cameron7710 Member
Posted: Wed Jun 04, 2008 9:39 pm Post subject: |
ya i got get on the job hunt _________________
Posted: Wed Jun 04, 2008 11:30 pm Post subject: |
| if it's after September i am there. |
cameron7710 Member
Posted: Thu Jun 05, 2008 12:33 am Post subject: |
ya no clue when this would be happening but im sure after September _________________
Jenn Member
Joined: 03 Feb 2007 Posts: 362 Location: hangin with my boys
1987 Pontiac Firebird
Posted: Thu Jun 05, 2008 8:37 am Post subject: |
just don't use a used clutch!  _________________
Posted: Thu Jun 05, 2008 9:32 am Post subject: |
Might be cheaper to get another car with body damage with a 5 speed in it. Then you'll be sure to have all the parts! I'm sure you can pick up a trashed 5sp for way under $1k. Especially if they don't know what they have. _________________ E30
Posted: Thu Jun 05, 2008 10:14 am Post subject: |
"under 1000" might not be cheaper. i bought a transmission, brand new clutch, brand new starter, and all the support hardware and it came in at less then $750. and that was a centerforce clutch too. if i had to do it again i'd go with a spec.
there is a part everyone seems to have missed... a starter. the automatic starters have a different nose cone then the manual starters. you can snag a junkyard nose cone, ands swap, or you can go out and get a new starter. a high torque mini starter sounds cool.  |
Posted: Thu Jun 05, 2008 10:19 am Post subject: |
| I think its easier to have a donor car beside your car so you are good to go with no unnecessary trips to the JY. Maybe my opinion is skewed though. We don't have any junkyards up here! The two closest yards are over an hour away. |
Posted: Thu Jun 05, 2008 10:23 am Post subject: |
i have to drive about thirty minutes. my swap took three days, if we had a donor car it would have taken two... maybe two late days. if i had known in advance that my used clutch was a bad idea it would have been two shorter days. i also should have had the flywheel resurfaced in advance.
but these are all things you overlook when Paul says "hey, lets put your transmission in this weekend"
a donor car is great. i'm sure there would be many other parts you could strip off of it as well to offset the cost of buying a whole other car. and if it runs and drives you can test your transmission before you install it. this will allow you not to end up with one that won't down shift into third....  |
