Urghh.. The cows curse...
Goto page 1, 2, 3  Next
PostPosted: Wed May 21, 2008 10:21 pm    Post subject: Urghh.. The cows curse... Reply with quote
Is hitting the portland crew as normal. I over heated on the way to Paul's today, and left a nice puddle of coolant in his driveway (sorry Dude!).
I think most of us are still working on getting our junk to cows. Mike isn't working on anything though, that might be a bad sign.
Ahh, if only the curse was just limited to Dyno weekend...
--John
PostPosted: Wed May 21, 2008 10:35 pm    Post subject: Reply with quote
The curse is limited to anytime thirdgens want to move in packs...
PostPosted: Thu May 22, 2008 12:00 am    Post subject: Reply with quote
I'm with stupid
I'm gonna be cutting it close, but I think between a few of us dedicated crewbies, we can get Paul, John and Myself up there in one piece.
Its just another adventure and story to tell later on....Very Happy
PostPosted: Thu May 22, 2008 12:15 am    Post subject: Reply with quote
It's going to make the beverages that much more enjoyable.
PostPosted: Sat May 24, 2008 8:35 pm    Post subject: Reply with quote
Ok, well newest issue, while coming down a hill today on my way home from work, when I hit the brakes at 60-70mph, the front end starts hopping and shaking, it was shaking the steering wheel, and the cowl was shaking pretty bad.
Not sure what this is. Brandon, any ideas. Paul and I are going to look at the steering parts, to see if we can find any slop in the tie rods or idler arm. Could it just be crusty old brakes/rotors if only one side did that, would it cause the wheel to shake like that?
Ohh, and I need a new coolant temp sensor, but of course that is easy.
PostPosted: Sat May 24, 2008 9:18 pm    Post subject: Reply with quote
My brakes are acting similarly. Only when I brake hard, then the steering wheel shakes back and forth quite hard sometimes. Last time it did this I thought one of the wheel bearings was a bit loose, took them apart, re greased them and put them back together and all seemed well. Only just recently it's started up again. Maybe time for a brake rebuild and having the rotors turned.
PostPosted: Sat May 24, 2008 9:49 pm    Post subject: Reply with quote
John, I have a Coolent temp sensor you can have for free. Its brand new in the box.
PostPosted: Sat May 24, 2008 9:50 pm    Post subject: Reply with quote
Sweet, that will save me $10. Can you bring it on tuesday when you come to get the wheels?
--John
PostPosted: Sat May 24, 2008 9:51 pm    Post subject: Reply with quote
I'll do it.
I just sent you a PM about it, you can disreguard that.
PostPosted: Sun May 25, 2008 9:23 am    Post subject: Reply with quote
Everytime there is a get together half the people break down or have problems. You people drive a bunch of crap. Very Happy
PostPosted: Sun May 25, 2008 10:09 am    Post subject: Reply with quote
Yes. But we do DRIVE them.
Very Happy
PostPosted: Sun May 25, 2008 10:23 am    Post subject: Reply with quote
Very Happy
I'm with stupid
Plus we chose to build 3rd gen Camaro's and Firebirds.
It's not like we started out with a big budget. Laughing
PostPosted: Sun May 25, 2008 10:25 am    Post subject: Reply with quote
Half of us have trouble getting there. When we get there; just Mike and Rod brake down. :O)
PostPosted: Sun May 25, 2008 10:30 am    Post subject: Reply with quote
Ouch!!!!
You just cursed yourself.
PostPosted: Sun May 25, 2008 12:03 pm    Post subject: Reply with quote
lol - I can't argue much with that based on my cows record. Surprised Brandon even lets me take my car on our cruises anymore I have ruined enough of them.
But ya, bad karma lad Tisk tisk
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Sun May 25, 2008 5:17 pm    Post subject: Re: Urghh.. The cows curse... Reply with quote
--John
I think the best way to get your junk to cows is knock it around a little bit.
PostPosted: Sun May 25, 2008 6:27 pm    Post subject: Reply with quote
Can't get any worse for me LOL
No axle under the Maro.
No brakes or Panhard bolt on the Chevette LOL
PostPosted: Sun May 25, 2008 6:35 pm    Post subject: Reply with quote
When are the axles supposed to be here ?? I thought tuesday they should be getting here.
--John
PostPosted: Sun May 25, 2008 6:52 pm    Post subject: Reply with quote
I have to replace my oil pan and timing cover.
Chain broke while I picked the motor up and dumped it nose first on the ground.
Then my motor hoist decided to lose all its pressure, so I couldn't pick it back up....and I lost the fill screw for it...
#$%^&* I swear to god man.....F--ing cows curse!!
PostPosted: Sun May 25, 2008 6:55 pm    Post subject: Reply with quote
Shocked is the engine OK? (other then the sheet metal)
Page 1 of 3
