Posted: Wed May 21, 2008 10:21 pm Post subject: Urghh.. The cows curse... |
Is hitting the portland crew as normal. I over heated on the way to Paul's today, and left a nice puddle of coolant in his driveway (sorry Dude!).
I think most of us are still working on getting our junk to cows. Mike isn't working on anything though, that might be a bad sign.
Ahh, if only the curse was just limited to Dyno weekend...
--John _________________
Posted: Wed May 21, 2008 10:35 pm Post subject: |
The curse is limited to anytime thirdgens want to move in packs... _________________
Posted: Thu May 22, 2008 12:00 am Post subject: |
I'm gonna be cutting it close, but I think between a few of us dedicated crewbies, we can get Paul, John and Myself up there in one piece.
Its just another adventure and story to tell later on.... _________________
Posted: Thu May 22, 2008 12:15 am Post subject: |
| It's going to make the beverages that much more enjoyable. |
Posted: Sat May 24, 2008 8:35 pm Post subject: |
Ok, well newest issue, while coming down a hill today on my way home from work, when I hit the brakes at 60-70mph, the front end starts hopping and shaking, it was shaking the steering wheel, and the cowl was shaking pretty bad.
Not sure what this is. Brandon, any ideas. Paul and I are going to look at the steering parts, to see if we can find any slop in the tie rods or idler arm. Could it just be crusty old brakes/rotors if only one side did that, would it cause the wheel to shake like that?
Ohh, and I need a new coolant temp sensor, but of course that is easy. |
Posted: Sat May 24, 2008 9:18 pm Post subject: |
My brakes are acting similarly. Only when I brake hard, then the steering wheel shakes back and forth quite hard sometimes. Last time it did this I thought one of the wheel bearings was a bit loose, took them apart, re greased them and put them back together and all seemed well. Only just recently it's started up again. Maybe time for a brake rebuild and having the rotors turned. _________________ 92 Camaro
Posted: Sat May 24, 2008 9:49 pm Post subject: |
| Dewey316 wrote: | Ok, well newest issue, while coming down a hill today on my way home from work, when I hit the brakes at 60-70mph, the front end starts hopping and shaking, it was shaking the steering wheel, and the cowl was shaking pretty bad.
John, I have a Coolent temp sensor you can have for free. Its brand new in the box. _________________
Posted: Sat May 24, 2008 9:50 pm Post subject: |
Sweet, that will save me $10. Can you bring it on tuesday when you come to get the wheels?
--John |
Posted: Sat May 24, 2008 9:51 pm Post subject: |
I'll do it.
I just sent you a PM about it, you can disreguard that. _________________
Posted: Sun May 25, 2008 9:23 am Post subject: |
Everytime there is a get together half the people break down or have problems. You people drive a bunch of crap.  |
Posted: Sun May 25, 2008 10:09 am Post subject: |
Yes. But we do DRIVE them.
Posted: Sun May 25, 2008 10:23 am Post subject: |
| Schultzy89GTA wrote: | Yes. But we do DRIVE them.
Plus we chose to build 3rd gen Camaro's and Firebirds.
It's not like we started out with a big budget.  |
Posted: Sun May 25, 2008 10:25 am Post subject: |
| Half of us have trouble getting there. When we get there; just Mike and Rod brake down. :O) |
Posted: Sun May 25, 2008 10:30 am Post subject: |
| Twilightoptics wrote: | | Half of us have trouble getting there. When we get there; just Mike and Rod brake down. :O) |
Ouch!!!!
You just cursed yourself. |
Posted: Sun May 25, 2008 12:03 pm Post subject: |
lol - I can't argue much with that based on my cows record. Surprised Brandon even lets me take my car on our cruises anymore I have ruined enough of them.
But ya, bad karma lad
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Sun May 25, 2008 5:17 pm Post subject: Re: Urghh.. The cows curse... |
| Dewey316 wrote: |
--John |
I think the best way to get your junk to cows is knock it around a little bit. _________________
Posted: Sun May 25, 2008 6:27 pm Post subject: |
Can't get any worse for me LOL
No axle under the Maro.
No brakes or Panhard bolt on the Chevette LOL |
Posted: Sun May 25, 2008 6:35 pm Post subject: |
When are the axles supposed to be here ?? I thought tuesday they should be getting here.
--John |
Posted: Sun May 25, 2008 6:52 pm Post subject: |
I have to replace my oil pan and timing cover.
Chain broke while I picked the motor up and dumped it nose first on the ground.
Then my motor hoist decided to lose all its pressure, so I couldn't pick it back up....and I lost the fill screw for it...
I swear to god man.....F--ing cows curse!! _________________
Posted: Sun May 25, 2008 6:55 pm Post subject: |
is the engine OK? (other then the sheet metal) |
