Question on 305
Project_1986_TA
PostPosted: Wed Feb 06, 2008 11:19 am    Post subject: Question on 305 Reply with quote
Does the LB9 305 crank have a 1 piece rear main seal? Im trying to sell my old motor and i have no idea.
View user's profile Send private message Yahoo Messenger MSN Messenger
305 302eater
PostPosted: Wed Feb 06, 2008 11:48 am    Post subject: Reply with quote
Yes it does.
Thirdgenless
PostPosted: Wed Feb 06, 2008 11:56 am    Post subject: Reply with quote
It depends on what year it is from.
PostPosted: Wed Feb 06, 2008 12:39 pm    Post subject: Reply with quote
You need to look at it then LOL.
A 1 piece rear seal will have a big round thing bolted to the back of the block.
A 2 piece rear seal all you'll see is block and crank.
86 they started the change over so it depends on when yours popped out.
Yes it does.
My '85 LB9 was a 2 piece. :O)
Project_1986_TA
PostPosted: Wed Feb 06, 2008 12:53 pm    Post subject: Reply with quote
mine was an '86. I might just have to look i guess. thanks guys
PostPosted: Wed Feb 06, 2008 1:33 pm    Post subject: Reply with quote
If the motor is original then it should have been a 2 piece. Are the valve covers center bolt or perimeter bolt. They did that switch at the same time as the rear main.
Project_1986_TA
PostPosted: Wed Feb 06, 2008 4:01 pm    Post subject: Reply with quote
i had perimeter bolts on the valve covers.
PostPosted: Wed Feb 06, 2008 4:02 pm    Post subject: Reply with quote
It is most likely a 2peice rear main then.
--John
PostPosted: Wed Feb 06, 2008 6:12 pm    Post subject: Reply with quote
I thought they switched to center bolt valve covers in '87?
PostPosted: Wed Feb 06, 2008 6:15 pm    Post subject: Reply with quote
They did.
and 1 piece rear main,
and roller cams
PostPosted: Wed Feb 06, 2008 6:35 pm    Post subject: Reply with quote
rjmcgee wrote:
They did.
and roller cams
Some '86 blocks were 1 piece rear, and cut for rollers but still had a tappet cam.
305 302eater
PostPosted: Wed Feb 06, 2008 9:30 pm    Post subject: Reply with quote
Ok my bad guess I'm used to the "newer" style small block. Thought the LB9's were one of those, thats why I said yes. Didn't know they came out in 85. And I thought I was a third gen geek. Laughing
Thirdgenless
PostPosted: Wed Feb 06, 2008 9:38 pm    Post subject: Reply with quote
I've got a motor out of an 86 Z ,.. its a 1 piece main, has the castings for a roller cam. But isnt machined for it, has a flat tappet. My 87 has roller and 1 piece main.
PostPosted: Sat Feb 09, 2008 11:47 am    Post subject: Reply with quote
Another way to tell is whether or not the flywheel has a counter balance (metal slug) attached to it. 1-piece rear mains need to be externally balanced by the flywheel. 2-piece rear mains were internally balanced except the 400 small block.
PostPosted: Sat Feb 09, 2008 7:13 pm    Post subject: Reply with quote
Negative. The thirdgen 1 piece rear motors are internally balanced.
