Project_1986_TA Member
Joined: 13 Jan 2004 Posts: 198 Location: Burien/Seatac
Posted: Wed Feb 06, 2008 11:19 am Post subject: Question on 305 |
| Does the LB9 305 crank have a 1 piece rear main seal? Im trying to sell my old motor and i have no idea. |
305 302eater Member
Posted: Wed Feb 06, 2008 11:48 am Post subject: |
Yes it does. _________________ Thirdgenless |
Posted: Wed Feb 06, 2008 11:56 am Post subject: |
| It depends on what year it is from. |
Posted: Wed Feb 06, 2008 12:39 pm Post subject: |
You need to look at it then LOL.
A 1 piece rear seal will have a big round thing bolted to the back of the block.
A 2 piece rear seal all you'll see is block and crank.
86 they started the change over so it depends on when yours popped out.
My '85 LB9 was a 2 piece. :O) |
Posted: Wed Feb 06, 2008 12:53 pm Post subject: |
| mine was an '86. I might just have to look i guess. thanks guys |
Posted: Wed Feb 06, 2008 1:33 pm Post subject: |
| If the motor is original then it should have been a 2 piece. Are the valve covers center bolt or perimeter bolt. They did that switch at the same time as the rear main. |
Posted: Wed Feb 06, 2008 4:01 pm Post subject: |
| i had perimeter bolts on the valve covers. |
Posted: Wed Feb 06, 2008 4:02 pm Post subject: |
It is most likely a 2peice rear main then.
--John |
Posted: Wed Feb 06, 2008 6:12 pm Post subject: |
I thought they switched to center bolt valve covers in '87? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Feb 06, 2008 6:15 pm Post subject: |
They did.
and 1 piece rear main,
and roller cams |
Posted: Wed Feb 06, 2008 6:35 pm Post subject: |
| rjmcgee wrote: | They did.
and roller cams |
Some '86 blocks were 1 piece rear, and cut for rollers but still had a tappet cam. |
305 302eater Member
Posted: Wed Feb 06, 2008 9:30 pm Post subject: |
Ok my bad guess I'm used to the "newer" style small block. Thought the LB9's were one of those, thats why I said yes. Didn't know they came out in 85. And I thought I was a third gen geek.  _________________ Thirdgenless |
Posted: Wed Feb 06, 2008 9:38 pm Post subject: |
| I've got a motor out of an 86 Z ,.. its a 1 piece main, has the castings for a roller cam. But isnt machined for it, has a flat tappet. My 87 has roller and 1 piece main. |
Posted: Sat Feb 09, 2008 11:47 am Post subject: |
| Another way to tell is whether or not the flywheel has a counter balance (metal slug) attached to it. 1-piece rear mains need to be externally balanced by the flywheel. 2-piece rear mains were internally balanced except the 400 small block. |
Posted: Sat Feb 09, 2008 7:13 pm Post subject: |
| QwkTrip wrote: | | 1-piece rear mains need to be externally balanced by the flywheel. |
Negative. The thirdgen 1 piece rear motors are internally balanced. |
