miamivice Member
1982 Pontiac Trans Am
Posted: Sun Jan 20, 2008 4:20 pm Post subject: |
are you sure its not a 2.73 fish?
did you pop the diff cover and look at the ring gear? GM gears have numbers. Formula for figuring the gear ratio is pretty simple.
The gear will usually Say "GM 11:41" or "GM (insert part number) 11:41"
What the equasion comes out to is this 41 ring teeth/11 pinion teeth=3.727272 = 3.73 rear ratio. _________________
miamivice Member
Posted: Sun Jan 20, 2008 4:54 pm Post subject: |
| Quasi-Traction wrote: | are you sure its not a 2.73 fish?
What the equasion comes out to is this 41 ring teeth/11 pinion teeth=3.727272 = 3.73 rear ratio. |
well...i just looked at the build sheet (didnt take anything apart). the code on the sheet reads GW9 and it is listed as 293 Ratio Axl
Posted: Sun Jan 20, 2008 5:13 pm Post subject: |
| Those are the proper bullets. But you need to know how many teeth that plastic gear in the trans has, and exactly what your rear end ratio is, and the size of your tires. Once you have all this there are online calculators to tell you how many teeth the driven gear needs to have. |
