Posted: Thu Jan 17, 2008 9:07 pm Post subject: IROC-Z sway bar |
Well I'm getting a free sway bar from someone who's parting out a formula that he says has an IROC sway bar on it. Looks beefier than mine at first glance but I take his word with a grain of salt. what's the diameter on one of these, 36mm? If so I'll hopefully have it installed sometime next week. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Jan 17, 2008 9:09 pm Post subject: |
IROCs came with 34mm
WS6 got the 36mm
--John |
Posted: Thu Jan 17, 2008 9:14 pm Post subject: |
Are both of them hollow John?
I just checked the bar out of Barts Trans Am against the one out of my IROC and found the TA one to be 30 mm while the IROC one was 34 mm
The 30mm bar weighed 19lbs/12 oz while the 34mm was 14lb/ 6 oz. |
Posted: Thu Jan 17, 2008 9:30 pm Post subject: |
My 34mm is hollow, I've heard solid ones were also available. I think the 36mm bars are all hollow. _________________ 92 Camaro
Posted: Thu Jan 17, 2008 9:44 pm Post subject: |
| the 36's i have handled were all hollow. the 34 i had on the six was hollow, and the 32 that replaced it was solid. |
Red Bird Member
1991 Pontiac Firebird
Posted: Thu Jan 17, 2008 9:46 pm Post subject: sway bar |
my 36mm bar is hollow, it has a little hole close to where the end link mounts, i think thats how you tell the difference between hollow and solid but not 100% _________________ 1991 Firebird L03 T-5 |
fiveoformula Member
Posted: Thu Jan 17, 2008 9:50 pm Post subject: |
dude, it is a WS6 sway bar... its off a formula, not a camaro _________________
'88 FORMULA |
Posted: Fri Jan 18, 2008 12:47 am Post subject: |
I do realize that if it were stock that it would be a WS6 sway bar but he told me that it was an IROC-Z sway bar that was swapped on there from an IROC. But this is coming from Cody so i doubt him until I have proof. Now if only I could find that caliper... _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
redlava Member
Posted: Fri Jan 18, 2008 1:46 am Post subject: |
| I know some irocs came with a 36mm sway bar. I got my 36mm sway bar from a 89 iroc. I think that was the only year that came with a 36mm though. |
Posted: Fri Jan 18, 2008 5:07 am Post subject: |
36 hallow
34 solid
34 hallow
32
30
for fronts, in order of strength |
Posted: Fri Jan 18, 2008 6:41 am Post subject: |
| DBL_TKE wrote: | | Now if only I could find that caliper... |
Que? What are you looking for?
Posted: Fri Jan 18, 2008 12:32 pm Post subject: |
My 34mm is a solid bar. _________________
Posted: Fri Jan 18, 2008 6:04 pm Post subject: |
| Schultzy89GTA wrote: | | DBL_TKE wrote: | | Now if only I could find that caliper... |
A caliper. Ya know, one of those fancy shmancy measuring dee-vices. _________________
Posted: Fri Jan 18, 2008 6:33 pm Post subject: |
ahhh I thought perhaps he meant a brake caliper. Thought I may have been in a position to help but you keep your dang hands off my fancy schmancy measurerer
kurfbird Member
Posted: Fri Jan 18, 2008 9:48 pm Post subject: |
You cna get one of those mesure devices at ace hardware for 10.00 I got one. The two iroc i have taken apart had 36 mm front sway bars. The Z 28 also has a 36 mm sway bar _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
fiveoformula Member
Posted: Fri Jan 18, 2008 11:14 pm Post subject: |
well codys car was pretty stock - one owner... im pretty sure nothing major was altered like that, if it has the stock wheels, stock exhaust, stock air box even... im pretty sure the sway bar is stock  _________________
'88 FORMULA |
Posted: Tue Jan 22, 2008 10:50 pm Post subject: |
Well I got the new sway bar all mounted up. I can't even begin to tell you how much of a difference it made. It cut down body roll substantially and virtually eliminated any understeer I had before. I seriously didn't think I would be able to tell the difference. BTW, we measured it and it was in fact a 36mm sway bar and my old one was a 32mm. The bar seemed pretty solid and as far as I could tell it was not hollow. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Jan 22, 2008 10:51 pm Post subject: |
| The larger front bar would make understeer worse. |
Posted: Tue Jan 22, 2008 11:04 pm Post subject: |
Yeah that's what I thought, have always learned, and know is true but IDK what to tell you. maybe it's just the right combination. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Wed Jan 23, 2008 12:00 am Post subject: |
| Dewey316 wrote: | | The larger front bar would make understeer worse. |
i can testify, i ran a 36 front bar and a 21 rear. man that thing would plow like a mother! once i threw the 24 rear bar on it handles like a dream!
~JAKE |
