IROC-Z sway bar
PostPosted: Thu Jan 17, 2008 9:07 pm    Post subject: IROC-Z sway bar Reply with quote
Well I'm getting a free sway bar from someone who's parting out a formula that he says has an IROC sway bar on it. Looks beefier than mine at first glance but I take his word with a grain of salt. what's the diameter on one of these, 36mm? If so I'll hopefully have it installed sometime next week.
PostPosted: Thu Jan 17, 2008 9:09 pm    Post subject: Reply with quote
IROCs came with 34mm
WS6 got the 36mm
--John
PostPosted: Thu Jan 17, 2008 9:14 pm    Post subject: Reply with quote
Are both of them hollow John?
I just checked the bar out of Barts Trans Am against the one out of my IROC and found the TA one to be 30 mm while the IROC one was 34 mm
The 30mm bar weighed 19lbs/12 oz while the 34mm was 14lb/ 6 oz.
PostPosted: Thu Jan 17, 2008 9:30 pm    Post subject: Reply with quote
My 34mm is hollow, I've heard solid ones were also available. I think the 36mm bars are all hollow.
PostPosted: Thu Jan 17, 2008 9:44 pm    Post subject: Reply with quote
the 36's i have handled were all hollow. the 34 i had on the six was hollow, and the 32 that replaced it was solid.
Red Bird
1991 Pontiac Firebird
PostPosted: Thu Jan 17, 2008 9:46 pm    Post subject: sway bar Reply with quote
my 36mm bar is hollow, it has a little hole close to where the end link mounts, i think thats how you tell the difference between hollow and solid but not 100%
1991 Firebird L03 T-5
PostPosted: Thu Jan 17, 2008 9:50 pm    Post subject: Reply with quote
dude, it is a WS6 sway bar... its off a formula, not a camaro
'88 FORMULA
PostPosted: Fri Jan 18, 2008 12:47 am    Post subject: Reply with quote
I do realize that if it were stock that it would be a WS6 sway bar but he told me that it was an IROC-Z sway bar that was swapped on there from an IROC. But this is coming from Cody so i doubt him until I have proof. Now if only I could find that caliper...
redlava
PostPosted: Fri Jan 18, 2008 1:46 am    Post subject: Reply with quote
I know some irocs came with a 36mm sway bar. I got my 36mm sway bar from a 89 iroc. I think that was the only year that came with a 36mm though.
PostPosted: Fri Jan 18, 2008 5:07 am    Post subject: Reply with quote
36 hallow
34 solid
34 hallow
32
30
for fronts, in order of strength
PostPosted: Fri Jan 18, 2008 6:41 am    Post subject: Reply with quote
Que? What are you looking for?
PostPosted: Fri Jan 18, 2008 12:32 pm    Post subject: Reply with quote
My 34mm is a solid bar.
PostPosted: Fri Jan 18, 2008 6:04 pm    Post subject: Reply with quote
A caliper. Ya know, one of those fancy shmancy measuring dee-vices.
PostPosted: Fri Jan 18, 2008 6:33 pm    Post subject: Reply with quote
ahhh I thought perhaps he meant a brake caliper. Thought I may have been in a position to help but you keep your dang hands off my fancy schmancy measurerer Razz
kurfbird
PostPosted: Fri Jan 18, 2008 9:48 pm    Post subject: Reply with quote
You cna get one of those mesure devices at ace hardware for 10.00 I got one. The two iroc i have taken apart had 36 mm front sway bars. The Z 28 also has a 36 mm sway bar
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Fri Jan 18, 2008 11:14 pm    Post subject: Reply with quote
well codys car was pretty stock - one owner... im pretty sure nothing major was altered like that, if it has the stock wheels, stock exhaust, stock air box even... im pretty sure the sway bar is stock Wink
'88 FORMULA
PostPosted: Tue Jan 22, 2008 10:50 pm    Post subject: Reply with quote
Well I got the new sway bar all mounted up. I can't even begin to tell you how much of a difference it made. It cut down body roll substantially and virtually eliminated any understeer I had before. I seriously didn't think I would be able to tell the difference. BTW, we measured it and it was in fact a 36mm sway bar and my old one was a 32mm. The bar seemed pretty solid and as far as I could tell it was not hollow.
PostPosted: Tue Jan 22, 2008 10:51 pm    Post subject: Reply with quote
The larger front bar would make understeer worse.
PostPosted: Tue Jan 22, 2008 11:04 pm    Post subject: Reply with quote
Yeah that's what I thought, have always learned, and know is true but IDK what to tell you. maybe it's just the right combination.
PostPosted: Wed Jan 23, 2008 12:00 am    Post subject: Reply with quote
i can testify, i ran a 36 front bar and a 21 rear. man that thing would plow like a mother! once i threw the 24 rear bar on it handles like a dream!
