Steering box.
PostPosted: Mon Jan 14, 2008 6:01 pm    Post subject: Steering box. Reply with quote
Looking to see if anyone has a steering box around, that itsn't all kinds of sloppy.
--John
mrpopo573
PostPosted: Mon Jan 14, 2008 7:48 pm    Post subject: Reply with quote
Tim, 305302 Eater may have one lying around. I know he has a parts IROC with things left.... he will be at the Dyno.
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
PostPosted: Mon Jan 14, 2008 8:07 pm    Post subject: Reply with quote
John,
I might Have one. lemmie see.
I saved a bunch of seering parts from my 84 SC. I know I didn't save the pump and the lines, but lemiie dig around and see if I have the box. I know I have the brakes and pittman arm and center link.
PostPosted: Mon Jan 14, 2008 10:36 pm    Post subject: Reply with quote
you wouldn't happen to have a pitman and idler arm that's in decent shape would you?
kurfbird
PostPosted: Tue Jan 15, 2008 2:35 pm    Post subject: Stering gear box Reply with quote
I ahve a sterring gear box from a 87 Z28 Camaro same box as Ws6. Idler arm seems good.
55.00 plus shipping for both
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sat Jun 14, 2008 8:03 pm    Post subject: Reply with quote
Bringing this back to see if anyone in the portland area has one sitting around, mine keeps getting sloppier, I am going to need to toss something in there.
--John
kurfbird
PostPosted: Sat Jun 14, 2008 8:26 pm    Post subject: adjustment Reply with quote
You can djust the slop out to some extent. USe a wrench and and allen wrench. Loose the nut then turn the allen wrench closkwise till the slop is removed about 1/4 to 1/2 at a time you will have to
drive to check the adjustment. And to be sure the sterring returns and does not get two tight.
I ahve done it a few times work great
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Sat Jun 14, 2008 8:27 pm    Post subject: Reply with quote
Done that a couple of times, it works for a couple of weeks, then the slop comes back.
kurfbird
PostPosted: Sat Jun 14, 2008 8:30 pm    Post subject: okay Reply with quote
Okay well sorry that about all I can suggest.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
batcave
PostPosted: Sun Jun 15, 2008 2:36 pm    Post subject: Reply with quote
i ve got a steering box out of an 87 ta 86,000 mile car
redlava
PostPosted: Wed Jun 18, 2008 4:25 pm    Post subject: Reply with quote
Look for one in a junkyard its only 3 bolts plus the 2 oil lines.
