Posted: Mon Jan 14, 2008 6:01 pm Post subject: Steering box. |
Looking to see if anyone has a steering box around, that itsn't all kinds of sloppy.
--John _________________
mrpopo573 Member
Posted: Mon Jan 14, 2008 7:48 pm Post subject: |
Tim, 305302 Eater may have one lying around. I know he has a parts IROC with things left.... he will be at the Dyno. _________________
2000 Maxima SE 5 Speed VQ30
Posted: Mon Jan 14, 2008 8:07 pm Post subject: |
John,
I might Have one. lemmie see.
I saved a bunch of seering parts from my 84 SC. I know I didn't save the pump and the lines, but lemiie dig around and see if I have the box. I know I have the brakes and pittman arm and center link. _________________
Posted: Mon Jan 14, 2008 10:36 pm Post subject: |
you wouldn't happen to have a pitman and idler arm that's in decent shape would you? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
kurfbird Member
Posted: Tue Jan 15, 2008 2:35 pm Post subject: Stering gear box |
I ahve a sterring gear box from a 87 Z28 Camaro same box as Ws6. Idler arm seems good.
55.00 plus shipping for both _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Sat Jun 14, 2008 8:03 pm Post subject: |
Bringing this back to see if anyone in the portland area has one sitting around, mine keeps getting sloppier, I am going to need to toss something in there.
--John |
kurfbird Member
Posted: Sat Jun 14, 2008 8:26 pm Post subject: adjustment |
You can djust the slop out to some extent. USe a wrench and and allen wrench. Loose the nut then turn the allen wrench closkwise till the slop is removed about 1/4 to 1/2 at a time you will have to
drive to check the adjustment. And to be sure the sterring returns and does not get two tight.
I ahve done it a few times work great _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Sat Jun 14, 2008 8:27 pm Post subject: |
| Done that a couple of times, it works for a couple of weeks, then the slop comes back. |
kurfbird Member
Posted: Sat Jun 14, 2008 8:30 pm Post subject: okay |
Okay well sorry that about all I can suggest. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
batcave Member
Posted: Sun Jun 15, 2008 2:36 pm Post subject: |
| i ve got a steering box out of an 87 ta 86,000 mile car |
redlava Member
Posted: Wed Jun 18, 2008 4:25 pm Post subject: |
| Look for one in a junkyard its only 3 bolts plus the 2 oil lines. |
