My Z is about ready to go back on the road... but questions:
Kage87Z
1969 Chevrolet Camaro
PostPosted: Sun Jan 13, 2008 5:56 pm    Post subject: My Z is about ready to go back on the road... but questions: Reply with quote
After only about 3 years. Sigh.
1. Would fried wiring to the trans (700R4) keep it from acting like it's got overdrive?
2. I need to replace the inner fender on the passenger side. Anything to look out for in that process?
Todd Beamer - 9/11
Never Forget
PostPosted: Sun Jan 13, 2008 5:58 pm    Post subject: Reply with quote
Those wires going to the trans are the TCC Torque Converter Lockup.
Without them, damaged, etc.... the converter wont lock up. It might seem like it doesn't have OD.
Kage87Z
PostPosted: Sun Jan 13, 2008 5:59 pm    Post subject: Reply with quote
OK... so, check the wiring harness there.
If that's OK, what's the next thing to look for?
Todd Beamer - 9/11
Never Forget
PostPosted: Mon Jan 14, 2008 8:44 am    Post subject: Reply with quote
You can check the brake switch and fuses. There is an input to the ECM that lets it know the brakes are on. The TC will disengage when the brakes are being pressed. I believe when you press the brakes the wire to the ECM goes to 12V.
Raiden
PostPosted: Mon Jan 14, 2008 9:08 am    Post subject: Reply with quote
I wonder if your TV cable is not adjusted properly? That will effect your shifts points.
Kage87Z
PostPosted: Mon Jan 14, 2008 1:02 pm    Post subject: Reply with quote
HHhhmmmmm..... definately worth a check. But it shifted fine before, and the shift cable hasn't been replaced: the fire was on the starter side and low... But I'll check that as well.
Also, I'll follow up with the fuse box. Good suggestions, gang.... thanks!
Todd Beamer - 9/11
Never Forget
PostPosted: Mon Jan 14, 2008 5:44 pm    Post subject: Reply with quote
The tv cable swaps over to that side, kind of behind the starter. I'd definatly check there for some meltage.
One other thing, it could just be gummed up from sitting 3 years too. One of the valves hanging or something. If you don't find any other problems, I'd add a can of Seafoam Trans Tune. I've had great success with this stuff. Both with sticky valve bodies, and shuddering convertors. If its just a gumming up issue it will take care of it in just a mile or 2 of driving.
Kage87Z
PostPosted: Tue Jan 15, 2008 12:45 am    Post subject: Reply with quote
will do. I'm a big seafoam fan.
Todd Beamer - 9/11
Never Forget
