Rust.
Brizio
1985 Chevrolet Camaro IROC-Z
PostPosted: Mon Jan 07, 2008 10:12 am    Post subject: Rust. Reply with quote
I need to remove or stop some rust on the car. Wich product is better?
Thanks
miamivice
1982 Pontiac Trans Am
PostPosted: Mon Jan 07, 2008 10:23 am    Post subject: Reply with quote
por15 or rust bullet are the best 2 products you can apply over 'rust' to stop them. both are good, ive seen both used on various projects and have held up very well although i think rust bullet is a little bit better bang for the buck and some of the product tests show better results.
most of the misc hardware on my car was coated in this. if you have outer panels with rust, however, you will want have them cut out and replaced w/ clean metal (depending on the quality of finish you are looking for) and then paint them w/ good epoxy primer...paint...
PostPosted: Mon Jan 07, 2008 10:32 am    Post subject: Reply with quote
Just call it "weight loss" you'll sleep better that way.
PostPosted: Mon Jan 07, 2008 11:07 am    Post subject: Reply with quote
I use phosphoric acid. Depends on where the rust is though. Iron has a greater affinity towards Iron Phosphate (FEPO4) than Iron Oxide (FE2O3 rust). So when you put it on it turns black, iron phosphate. The wonderous thing about FEPO4 is that its water soluble.
So basically slather it in naval jelly and wash the rust off. Reapply as necessary and paint when done. Very Happy
PostPosted: Mon Jan 07, 2008 3:44 pm    Post subject: Reply with quote
you could also wire wheel it and throw some primer and paint on it.
Kage87Z
1969 Chevrolet Camaro
PostPosted: Mon Jan 07, 2008 5:51 pm    Post subject: Reply with quote
I use "cutting wheel/torch."
Todd Beamer - 9/11
Never Forget
PostPosted: Mon Jan 07, 2008 6:00 pm    Post subject: Reply with quote
If its external body panel damage, then ya..cut it out and weld in some new metal. If its like your floorboard or something, then go ahead and por15 it. A little por15 goes a long ways though. It only took 1 quart to do my entire 67 stepside chassis, with a little left over. Por15 does not like clean sheet metal though. It takes more preperation to make it stick to clean metal then rust. With rust you just have to make sure its degreased, knock the large scale off, then paint it on with a brush. It's self leveling so it'll leave no brush marks. I've not tried rust bullet yet, so not sure how well it works. Eastwood rust encapsulator(Corroless) works well too, but its very hard to topcoat. I used it on my 64 velle and then used bedliner over the top of it. Bedliner started peeling a couple years later. Alot of the so called rust stopping primers are a total waste of money in my opinion. They're a quick fix that'll last a year maybe 2.
Brizio
PostPosted: Tue Jan 08, 2008 12:08 pm    Post subject: Reply with quote
Where I can find some of this products?
The rust is not too much, but it's in some part of the interior of the door. So i want stop it before put the banel.
PostPosted: Tue Jan 08, 2008 12:30 pm    Post subject: Reply with quote
Marine or Auto stores should have a couple of selections.
Brizio
PostPosted: Tue Jan 08, 2008 1:05 pm    Post subject: Reply with quote
Thanks!
