Cascade Crew Message Forums
Posted: Mon Dec 17, 2007 4:37 am Post subject: |
| Demon wrote: | | STEEL wrote: | | Demon wrote: | | Quasi-Traction wrote: | | rjmcgee wrote: | | Quasi-Traction wrote: | | Demon wrote: | | rjmcgee wrote: | | I didn't use it in my blue car, I just got the heads changed on my red TPI car. I think it already plugged the fuel filter though. Can't really take it out and drive it far though until I swtch the title to my name and license it. Just didn't want to spend that money until I was sure that I wasn't parting it out. | what's wrong with it?
you and I ... we should chat... |
Aaron, Rod's got another 82 Z/28, if you're in the market for a 3rd gen. You might an easier time talking him out of that, than the TPI car. Although, I think he wants to keep the 82 around for parts.
Its pink! Right up your alley...
I have the hood off of it, but I"d be willing to give it back to you (maily just tired of the "hello kitty" references) |
Are you serious?
A can of white paint is your friend Chris.  |
No, not serious. Its the hood I want. It just has a few blemishes.
I need to find someone with some expertice in fiberglass repair for it though, before I address paint on it. | those hoods are a bitch to fix even WITH fiberglass knowledge because its not 100% fiberglass...
they're known for separating as well |
Ya, how do you fix a separating hood? |
silly putty and lots of duct tape.
it's the reason that the same hood was steel for 1984 models ... huge recall on them... both functional and non-functional composite hoods had the problem... the skin would eventually separate where they were basically glued, and apparently it was a problem at high speeds... you know... hood halves flying off willynilly and all...
not sure what the fix was, I believe it was the steel replacement hood, bt you could fix it with some glass work and rivets or something I'm sure |
Huh?....I never knew they made the 84's out of steel. My 84 camaro had a Fiberglass hood, of course it was also a CFI Hood with flappers, and definately wasn't orginal to the car.
Mine's having the "seperating" problem on the driver side uppper corner.
Guess its time to buy a bunch of 2 stage epoxy!
Man, all this talk about hoods.....I think its time to bust out the orbital sander and the 160 grit sheets and strip that pink color off! _________________
Demon 12sec Club
Posted: Mon Dec 17, 2007 6:32 am Post subject: |
| Quasi-Traction wrote: | | Demon wrote: | | STEEL wrote: | | Demon wrote: | | Quasi-Traction wrote: | | rjmcgee wrote: | | Quasi-Traction wrote: | | Demon wrote: | | rjmcgee wrote: | | I didn't use it in my blue car, I just got the heads changed on my red TPI car. I think it already plugged the fuel filter though. Can't really take it out and drive it far though until I swtch the title to my name and license it. Just didn't want to spend that money until I was sure that I wasn't parting it out. | what's wrong with it?
Are you serious?
Man, all this talk about hoods.....I think its time to bust out the orbital sander and the 160 grit sheets and strip that pink color off! | sad but true... and yeah, the CFI hood would be the dead give away it wasn't original haha...
as much as I love the hoods, a low cowl would do me just fine when it comes down to it |
Posted: Mon Dec 17, 2007 8:10 am Post subject: |
Enough with the full page quotes guys. If quoting a previous post is needed to add clarity to your comment then feel free. Otherwise, just reply. Thanks.
: finger on lock :
STEEL Member
Posted: Mon Dec 17, 2007 2:03 pm Post subject: |
| Hey chris, you cant see it in the pics, but mine is separating BAD. It sounds like you have some experience with fixing these things, could you give me detailed idiot proof instructions? |
Posted: Mon Dec 17, 2007 9:35 pm Post subject: |
| STEEL wrote: | | Hey chris, you cant see it in the pics, but mine is separating BAD. It sounds like you have some experience with fixing these things, could you give me detailed idiot proof instructions? |
I have NO experience repairing these things. Even I could use a few pointers on what to do.
I'm amidst sanding the pink color off mine right now. I'll probably do the actual repair to where its seperating next week (weather permitting).
I wish I could be of assistance, but I myself am not 100% sure, so it'd be like the blind leading the blind. _________________
Vaneat-91RS Member
Posted: Wed Dec 19, 2007 3:54 pm Post subject: |
| iansane wrote: | | Demon wrote: | | iansane wrote: | | The ones I always hear are the best are the Chevron stuff and the Lucas. And the lucas is cheap! $2-3 a bottle. | you have, available to you at the dealership... something far more potent... I forget what it's called but I was given a few cans of it... worked out nicely on an older car too... lol
next week when I have the time, I want to do the seafoam treatment to selma's car... its old, it needs it, haha |
That's just seafoam I think... |
I think you are refering to Top Engine Cleaner. Part # 105002. There is also a new product called upper engine and injector cleaner, part# 88861802. _________________ Vaneat-91RS
Justin |
Posted: Wed Dec 19, 2007 4:10 pm Post subject: |
| Vaneat-91RS wrote: | | I think you are refering to Top Engine Cleaner. Part # 105002. There is also a new product called upper engine and injector cleaner, part# 88861802. |
105002 is the old GM number for 88861802. They switched awhile ago. Comes in a cantainer like Stabil. |
Vaneat-91RS Member
Posted: Wed Dec 19, 2007 6:57 pm Post subject: |
| iansane wrote: | | Vaneat-91RS wrote: | | I think you are refering to Top Engine Cleaner. Part # 105002. There is also a new product called upper engine and injector cleaner, part# 88861802. |
Yep we did. But some of us still have secret stashes of the old stuff laying around. You could actually still get the old number until about last February. If you ask nice, I'm sure your local dealer has a can or two of the old laying around you could obtain for a more reasonable price.
Justin |
Sellmanb Member
Posted: Wed Dec 19, 2007 7:42 pm Post subject: |
| Vaneat-91RS wrote: | | iansane wrote: | | Vaneat-91RS wrote: | | I think you are refering to Top Engine Cleaner. Part # 105002. There is also a new product called upper engine and injector cleaner, part# 88861802. |
The old stuff was found to the state of california to emit too many pollutants, which is cause for the switch. I know that my work is all out of it, but we rarely use it anyways, way overkill. |
Vaneat-91RS Member
Posted: Mon Dec 31, 2007 4:59 pm Post subject: |
Yep. Same reason you can't get EOS anymore either. Boy, do I hear about that all the time. _________________ Vaneat-91RS
Justin |
