Fuel injector cleaner
Goto page Previous  1, 2, 3
PostPosted: Mon Dec 17, 2007 4:37 am    Post subject: Reply with quote
Demon wrote:
STEEL wrote:
Demon wrote:
Quasi-Traction wrote:
Demon wrote:
rjmcgee wrote:
I didn't use it in my blue car, I just got the heads changed on my red TPI car. I think it already plugged the fuel filter though. Can't really take it out and drive it far though until I swtch the title to my name and license it. Just didn't want to spend that money until I was sure that I wasn't parting it out.
what's wrong with it?
you and I ... we should chat...
Aaron, Rod's got another 82 Z/28, if you're in the market for a 3rd gen. You might an easier time talking him out of that, than the TPI car. Although, I think he wants to keep the 82 around for parts.
Its pink! Right up your alley... Wink
I have the hood off of it, but I"d be willing to give it back to you (maily just tired of the "hello kitty" references)
Are you serious?
A can of white paint is your friend Chris. Idea
No, not serious. Its the hood I want. It just has a few blemishes.
I need to find someone with some expertice in fiberglass repair for it though, before I address paint on it.
those hoods are a bitch to fix even WITH fiberglass knowledge because its not 100% fiberglass...
they're known for separating as well
Ya, how do you fix a separating hood?
silly putty and lots of duct tape.
it's the reason that the same hood was steel for 1984 models ... huge recall on them... both functional and non-functional composite hoods had the problem... the skin would eventually separate where they were basically glued, and apparently it was a problem at high speeds... you know... hood halves flying off willynilly and all...
not sure what the fix was, I believe it was the steel replacement hood, bt you could fix it with some glass work and rivets or something I'm sure
Huh?....I never knew they made the 84's out of steel. My 84 camaro had a Fiberglass hood, of course it was also a CFI Hood with flappers, and definately wasn't orginal to the car.
Mine's having the "seperating" problem on the driver side uppper corner.
Guess its time to buy a bunch of 2 stage epoxy!
Man, all this talk about hoods.....I think its time to bust out the orbital sander and the 160 grit sheets and strip that pink color off!
Demon
PostPosted: Mon Dec 17, 2007 6:32 am    Post subject: Reply with quote
Are you serious?
sad but true... and yeah, the CFI hood would be the dead give away it wasn't original haha...
as much as I love the hoods, a low cowl would do me just fine when it comes down to it
PostPosted: Mon Dec 17, 2007 8:10 am    Post subject: Reply with quote
Enough with the full page quotes guys. If quoting a previous post is needed to add clarity to your comment then feel free. Otherwise, just reply. Thanks.
: finger on lock :
STEEL
PostPosted: Mon Dec 17, 2007 2:03 pm    Post subject: Reply with quote
Hey chris, you cant see it in the pics, but mine is separating BAD. It sounds like you have some experience with fixing these things, could you give me detailed idiot proof instructions?
PostPosted: Mon Dec 17, 2007 9:35 pm    Post subject: Reply with quote
I have NO experience repairing these things. Even I could use a few pointers on what to do.
I'm amidst sanding the pink color off mine right now. I'll probably do the actual repair to where its seperating next week (weather permitting).
I wish I could be of assistance, but I myself am not 100% sure, so it'd be like the blind leading the blind.
Vaneat-91RS
PostPosted: Wed Dec 19, 2007 3:54 pm    Post subject: Reply with quote
Demon wrote:
The ones I always hear are the best are the Chevron stuff and the Lucas. And the lucas is cheap! $2-3 a bottle.
you have, available to you at the dealership... something far more potent... I forget what it's called but I was given a few cans of it... worked out nicely on an older car too... lol
next week when I have the time, I want to do the seafoam treatment to selma's car... its old, it needs it, haha
That's just seafoam I think...
I think you are refering to Top Engine Cleaner. Part # 105002. There is also a new product called upper engine and injector cleaner, part# 88861802.
Vaneat-91RS
Justin
PostPosted: Wed Dec 19, 2007 4:10 pm    Post subject: Reply with quote
105002 is the old GM number for 88861802. They switched awhile ago. Smile Comes in a cantainer like Stabil.
Vaneat-91RS
PostPosted: Wed Dec 19, 2007 6:57 pm    Post subject: Reply with quote
Yep we did. But some of us still have secret stashes of the old stuff laying around. You could actually still get the old number until about last February. If you ask nice, I'm sure your local dealer has a can or two of the old laying around you could obtain for a more reasonable price.
Thumbs up
Vaneat-91RS
Justin
Sellmanb
PostPosted: Wed Dec 19, 2007 7:42 pm    Post subject: Reply with quote
Thumbs up
The old stuff was found to the state of california to emit too many pollutants, which is cause for the switch. I know that my work is all out of it, but we rarely use it anyways, way overkill.
Vaneat-91RS
PostPosted: Mon Dec 31, 2007 4:59 pm    Post subject: Reply with quote
Yep. Same reason you can't get EOS anymore either. Boy, do I hear about that all the time.
Vaneat-91RS
Justin
Page 3 of 3
