1985 AC delete.
STEEL
PostPosted: Mon Nov 12, 2007 3:04 pm    Post subject: 1985 AC delete. Reply with quote
Ok, its a V belt set up, and so do I still need to put another idler in there? Or do I just un bolt it and throw it away?
The cruise doesn't work, so do I need to be away of anything before I start ripping it out?
PostPosted: Mon Nov 12, 2007 3:09 pm    Post subject: Re: 1985 AC delete. Reply with quote
Yes. Mine has two belts, one for the PS pump, and one for the water pump and alt.
Tony had a really good (albeit poorly spelt Razz) writeup on deleting cruise control. Lemme see if I can find it.
*Edit:
http://cascadecrew.org/phpBB2/viewtopic.php?t=2720
http://www.thirdgen.org/techboard/v6/367114-cruise-control-delete.html
http://www.thirdgen.org/techboard/v6/369778-cruise-control-help.html
*Edit #2: If you need pics of anything, let me know. I can grab some from my IROC.
PostPosted: Mon Nov 12, 2007 5:39 pm    Post subject: Reply with quote
I second. You only need an idler for a single belt setup.
PostPosted: Mon Nov 12, 2007 11:02 pm    Post subject: Reply with quote
I'l correct that and say you only need an Idler with a Serp setup. you can delete the belt (and in your case the AC) and be ok.
PostPosted: Mon Nov 12, 2007 11:38 pm    Post subject: Reply with quote
I'm looking to restore my AC setup so if you are planning on "throwing away" any useable parts PLEASE let me have! Good luck with all of it!
PostPosted: Tue Nov 13, 2007 12:20 am    Post subject: Reply with quote
I deleted my A/C by simply unbolting everything and ripping all the associating parts out of there. I also have an '85 with a V belt. BTW I think I saved some of my A/C components in case you're interested Jake.
PostPosted: Tue Nov 13, 2007 12:29 am    Post subject: Reply with quote
Yeah i need a new compressor for sure, and any other random parts that may need replacing. Let me know what you may have Smile
PS sorry for the tangent
PostPosted: Tue Nov 13, 2007 9:39 am    Post subject: Reply with quote
Jake, was your car a base model, or did someone pull the AC along the line? I ask because the interior heater box and dash are different with AC, so adding it to a base model car looks like quite a bit of work.
PostPosted: Tue Nov 13, 2007 9:43 am    Post subject: Reply with quote
I seem to recall Jake's A/C is still in the car. His compressor is shot though, among other things.
PostPosted: Tue Nov 13, 2007 2:32 pm    Post subject: Reply with quote
yeah, like Al said, I have it all there, its just not working properly. So if i had someones misc parts i could piece mine back together to get it working again.
Black Car + no T tops + No AC + Hot day = Sad
HOWEVER:
Black Car + AC = Cool<-- JAKE
PostPosted: Tue Nov 13, 2007 3:59 pm    Post subject: Reply with quote
Jake, you might be better off to get a new compressor and recharge your system with 134a. Less expensive that way (ask me how I know). R12 is way expensive and it's lubricant is not compatible with the lubricant 134a uses.
New compressor, new orifice tube and a new pressure switch I believe is what you need to get (someone add more if I'm wrong), then evacuate the system and charge with 134a. Doing all that is less than a new compressor and recharging with R12.
PostPosted: Tue Nov 13, 2007 4:34 pm    Post subject: Reply with quote
If you're doing that work a new evaporator would be a good idea as well, those things will accumulate all the junk and debris that builds up in the system.
PostPosted: Tue Nov 13, 2007 6:44 pm    Post subject: Reply with quote
That would be a good idea come to think of it. I left mine in though when the compressor crapped out. Did a good evacuation, changed all the O-rings and the other stuff mentioned, then recharged with the new stuff.
PostPosted: Tue Nov 13, 2007 10:27 pm    Post subject: Reply with quote
i went to publik skool. so i spells good. Sad
PostPosted: Tue Nov 13, 2007 11:05 pm    Post subject: Reply with quote
Sorry man, it's just that when I deleted mine I printed up your guide and was reading it while laying upside down under my dash, and kept cracking up trying to read it. Laughing
