kurfbird Member
Posted: Mon Sep 24, 2007 7:40 pm Post subject: Planing suspension rebuilt |
Okay decided to to a suspension rebuild on my daily driver 3.1 v6 auto 92 firebird next spring. Has 158,000 miles on it. So I am getting the necessary parts together now.
Got a poly energy suspension bushing kit.
New Ball joints (One is going out but figure I can wait until next spring)
Going to get a set of spindles and a arms (blue89 hopefully)
Already have the rear control arms and panhard bar. I plan on replacing the bushing on the spare set then swap out the parts when that complete.
New inner tire rod ends
Have transam sway bars front and rear. Going for new bushings and end links for these also.
Outer tire rods ends and idler arm were replaced last year
New gear box and power steeering pump only has 12,000 miles on it. Its from my 89 XS.
Trans mount has been replaced. Part of last months engine problem.
Have new shocks and struts probably like 20,000 miles on them.
Have wonder bar installed
Strut tower brace (two point)
Have new rotors and calipers
Not really interested in sub frame conectors on this car.
Questions 1 What springs should I use. With the amount of miles on the car new springs could help the ride.
Is ther any other mods (near stock that I can do) _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Mon Sep 24, 2007 8:10 pm Post subject: |
| Did you replace the strut bearings? I didnt when i first did struts, but it needed it shortly after. |
kurfbird Member
Posted: Mon Sep 24, 2007 8:13 pm Post subject: Strut bushings |
No have not replaced them. What type did you use ??
Something to look at. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Sep 24, 2007 8:19 pm Post subject: |
| I just used stock.. cause i could afford them. But several are using the aluminum type that Alloy used to make. |
kurfbird Member
Posted: Mon Sep 24, 2007 8:23 pm Post subject: I will look at them |
I will take a look at them for replacement _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
