power ant.
pathology knight
PostPosted: Thu Jul 19, 2007 7:48 am    Post subject: power ant. Reply with quote
i know there's been discussion before about the power ant that some of us have. what i've heard, it that the "universal" ones don't really fit our cars.
can somone tell me what i need? Confused
thanks.
PostPosted: Thu Jul 19, 2007 1:17 pm    Post subject: Reply with quote
the stock one.
$200+ from GM
PostPosted: Thu Jul 19, 2007 1:21 pm    Post subject: Reply with quote
What's wrong with it? Unless you managed to snap it off, you may be able to fix the one you have.
pathology knight
PostPosted: Thu Jul 19, 2007 2:45 pm    Post subject: Reply with quote
the stock one! $200! Bashy Bashy
crap....
the problem with it is the actual antanae that sticks up through the fender....it's not there! well there's a piece about 8" that sticks up, but the rest of its gone.
PostPosted: Thu Jul 19, 2007 3:00 pm    Post subject: Reply with quote
Junkyard. A pain to remove unless you pull the fender though.
PostPosted: Thu Jul 19, 2007 3:09 pm    Post subject: Reply with quote
just shave it! thats what i did, looks cool Cool
PostPosted: Thu Jul 19, 2007 3:33 pm    Post subject: Reply with quote
I used a universal. Between $30-$40 IIRC. Simple to remove the old and install the new. Access through plastic cover inside the wheel well.
Cheap and easy. You could remove the old one first to compare to the dimensions of whatever unit you pick up.
Good luck.
pathology knight
PostPosted: Fri Jul 20, 2007 6:32 am    Post subject: Reply with quote
shaved wouldn't be to bad....tell me more! Cool
i'm replacing the fenders next weekend, so i figured i would fix it while they're off.
PostPosted: Fri Jul 20, 2007 7:15 am    Post subject: Reply with quote
go to the junkyard and get a fixed antenna. then mount it under your dashpad. like this:
or you can go to any car audio shoppe and get a "marine antenna". this is ment for boats and such, it is two wires that you stretch out under your dash. these do not quite work as well. then you are left with a hole in your fender. this is where i currently am with both cars. theory is that you would then weld the hole shut, smooth it out and paint it.
PostPosted: Fri Jul 20, 2007 7:23 am    Post subject: Reply with quote
Like this!
here's the whole process on my car domain site
http://www.cardomain.com/ride/2474895/4
PostPosted: Fri Jul 20, 2007 9:14 am    Post subject: Reply with quote
I thought the marine antennas got better reception?
Old saying that use to be used in the mini truck world
"I like my trucks like my woman, fully shaved"
PostPosted: Mon Jul 23, 2007 7:20 pm    Post subject: Reply with quote
Shaved is neat, but the power anntenae is the way to go for best of both worlds. I hate static on my radio.
PostPosted: Mon Jul 23, 2007 7:51 pm    Post subject: Reply with quote
shaved is neat. I need to get around to doing that pretty soon.
PostPosted: Mon Jul 23, 2007 9:25 pm    Post subject: Reply with quote
i noticed ZERO change in my reception when i put my whip under the dash. i DID notice a decrease when i switched to the marine antenna. next time i hit the junkyard i will snag a stock antenna mount.
pathology knight
PostPosted: Tue Jul 24, 2007 3:50 pm    Post subject: Reply with quote
a couple things...
if i put the ant under the dash pad, it doesn't have to be a stock one right? i mean, since it's not going in the fender, it doesn't really matter how it mounts, does it?
also, this might sound stupid, but how does it hook up? i know there's teh little plug in that goes in the back of your radio, but if i get an aftermarket fixed ant, is that all it has? i would imagine a power one has more (for power) but i like the idea of having a clean fender, but at the same time no static. i hate static! Rolling Eyes
putting it under the dash pad seems like a really neat idea. Idea
PostPosted: Tue Jul 24, 2007 8:49 pm    Post subject: Reply with quote
Any aftermarket fixed antenna should have the normal universal line and fitting. A power one will have leads for 12v, remote, and ground.
For what it's worth, I like my stock power antenna for looks and usability, so I would stick with that.
pathology knight
PostPosted: Wed Jul 25, 2007 7:59 am    Post subject: Reply with quote
true, but i'm not shelling out $200 for an antanna.
PostPosted: Wed Jul 25, 2007 8:02 am    Post subject: Reply with quote
correct, it will not matter what fixed antenna you go with
PostPosted: Wed Jul 25, 2007 8:45 am    Post subject: Reply with quote
Then try the scrap yard, or like Schultzy said, get a universal power antenna. Hey, if you're lazy just look on TGO. Always someone parting out cars there.
