pathology knight Member
Posted: Thu Jul 19, 2007 7:48 am Post subject: power ant. |
i know there's been discussion before about the power ant that some of us have. what i've heard, it that the "universal" ones don't really fit our cars.
can somone tell me what i need?
thanks. _________________ we all gotta start somewhere.... |
Posted: Thu Jul 19, 2007 1:17 pm Post subject: |
the stock one.
$200+ from GM |
Posted: Thu Jul 19, 2007 1:21 pm Post subject: |
| What's wrong with it? Unless you managed to snap it off, you may be able to fix the one you have. |
Posted: Thu Jul 19, 2007 2:45 pm Post subject: |
the stock one! $200!
crap....
the problem with it is the actual antanae that sticks up through the fender....it's not there! well there's a piece about 8" that sticks up, but the rest of its gone. _________________ we all gotta start somewhere.... |
Posted: Thu Jul 19, 2007 3:00 pm Post subject: |
| Junkyard. A pain to remove unless you pull the fender though. |
Posted: Thu Jul 19, 2007 3:09 pm Post subject: |
just shave it! thats what i did, looks cool
Posted: Thu Jul 19, 2007 3:33 pm Post subject: |
I used a universal. Between $30-$40 IIRC. Simple to remove the old and install the new. Access through plastic cover inside the wheel well.
Cheap and easy. You could remove the old one first to compare to the dimensions of whatever unit you pick up.
Good luck.
Posted: Fri Jul 20, 2007 6:32 am Post subject: |
shaved wouldn't be to bad....tell me more!
i'm replacing the fenders next weekend, so i figured i would fix it while they're off. _________________ we all gotta start somewhere.... |
Posted: Fri Jul 20, 2007 7:15 am Post subject: |
go to the junkyard and get a fixed antenna. then mount it under your dashpad. like this:
or you can go to any car audio shoppe and get a "marine antenna". this is ment for boats and such, it is two wires that you stretch out under your dash. these do not quite work as well. then you are left with a hole in your fender. this is where i currently am with both cars. theory is that you would then weld the hole shut, smooth it out and paint it. |
Posted: Fri Jul 20, 2007 7:23 am Post subject: |
| Xophertony wrote: | | theory is that you would then weld the hole shut, smooth it out and paint it. |
Like this!
here's the whole process on my car domain site
http://www.cardomain.com/ride/2474895/4
~JAKE |
Posted: Fri Jul 20, 2007 9:14 am Post subject: |
I thought the marine antennas got better reception?
Old saying that use to be used in the mini truck world
"I like my trucks like my woman, fully shaved" |
Posted: Mon Jul 23, 2007 7:20 pm Post subject: |
| Shaved is neat, but the power anntenae is the way to go for best of both worlds. I hate static on my radio. |
Posted: Mon Jul 23, 2007 7:51 pm Post subject: |
shaved is neat. I need to get around to doing that pretty soon. _________________
Posted: Mon Jul 23, 2007 9:25 pm Post subject: |
| i noticed ZERO change in my reception when i put my whip under the dash. i DID notice a decrease when i switched to the marine antenna. next time i hit the junkyard i will snag a stock antenna mount. |
Posted: Tue Jul 24, 2007 3:50 pm Post subject: |
a couple things...
if i put the ant under the dash pad, it doesn't have to be a stock one right? i mean, since it's not going in the fender, it doesn't really matter how it mounts, does it?
also, this might sound stupid, but how does it hook up? i know there's teh little plug in that goes in the back of your radio, but if i get an aftermarket fixed ant, is that all it has? i would imagine a power one has more (for power) but i like the idea of having a clean fender, but at the same time no static. i hate static!
putting it under the dash pad seems like a really neat idea.  _________________ we all gotta start somewhere.... |
Posted: Tue Jul 24, 2007 8:49 pm Post subject: |
Any aftermarket fixed antenna should have the normal universal line and fitting. A power one will have leads for 12v, remote, and ground.
For what it's worth, I like my stock power antenna for looks and usability, so I would stick with that. |
Posted: Wed Jul 25, 2007 7:59 am Post subject: |
true, but i'm not shelling out $200 for an antanna. _________________ we all gotta start somewhere.... |
Posted: Wed Jul 25, 2007 8:02 am Post subject: |
| correct, it will not matter what fixed antenna you go with |
Posted: Wed Jul 25, 2007 8:45 am Post subject: |
| pathology knight wrote: | | true, but i'm not shelling out $200 for an antanna. |
Then try the scrap yard, or like Schultzy said, get a universal power antenna. Hey, if you're lazy just look on TGO. Always someone parting out cars there. |
