misc parts WTB, mostly TPI
PostPosted: Wed May 23, 2007 4:26 am    Post subject: misc parts WTB, mostly TPI Reply with quote
looking for some parts, no major hurry. Price is more an issue then finding or time. All for 91 Camaro
36mm Front sway
black door sill plate
right side GM power lock
pwr window switch
2 left, and 2 right 82-87?? style tail lights. 2 could be broke in certin areas.
TPI Parts:
91-92 harness
custom burned prom to fit moates G3 adaptor to get me started
used stuff to burn my own chips
PostPosted: Wed May 23, 2007 7:17 am    Post subject: Reply with quote
Kurfbird might have a lot of these parts. He JUST sold a TPI unit and is in the market of scraping 3rd gens.
PostPosted: Wed May 23, 2007 7:38 am    Post subject: Re: misc parts WTB, mostly TPI Reply with quote
Do you want the cylinder, the actuator, the harness, the linkage? There are a lot of parts in those locks.
kurfbird
PostPosted: Wed May 23, 2007 7:41 am    Post subject: Parts Reply with quote
I am not in the market to scraping third gens Wink . But I do have some parts.
I only have the throttle bracket for the TPI. Everything else is gone. Sorry.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Wed May 23, 2007 9:37 am    Post subject: Re: misc parts WTB, mostly TPI Reply with quote
The actuator, sorry. I have to hit the lock button several times to make it do whats needed.
PostPosted: Wed May 23, 2007 9:39 am    Post subject: Re: Parts Reply with quote
Got any of the other non tpi parts?
If you *cough* come across some of the other parts on a car, please keep me in mind.
PostPosted: Wed May 23, 2007 9:47 am    Post subject: Reply with quote
I have couple of tail-lights that are the late model RS type, with the black stripe. Not exactly the same as the early ones, but clsoe.
kurfbird
PostPosted: Wed May 23, 2007 9:57 am    Post subject: Parts Reply with quote
I might have the aucator and power mirror switch. I will check tonight and get back to you.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird
PostPosted: Wed May 23, 2007 10:00 am    Post subject: Actuator Reply with quote
You might want to take you door panels off and lubricatre everything really well. Mine was doing that and I used some spray lub and now it works great.
ALso the actuator peices that goes on the door rod inside the door itself spreads out over time. I took mine off and pinched it back together with vice gripes and that helped alot.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Wed May 23, 2007 11:02 am    Post subject: Re: Parts Reply with quote
Window switch, not mirror switch.
Door panels are off right now, so I'll look at the linkages. Door rod spreads out?? Confused Kinda confused on that.
kurfbird
PostPosted: Wed May 23, 2007 11:58 am    Post subject: Door linkage. Reply with quote
Look where the linkage goes into the lock actuator. Looks like a Y peice of emtal with a clamp like opening
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Thu May 24, 2007 3:53 am    Post subject: Reply with quote
ok, will look at this tonight.
PostPosted: Thu May 24, 2007 5:43 pm    Post subject: Reply with quote
ok, I see what you mean on spreads out. Its no bigger then the left side. Since I was spraying primer tonight, I didnt want to pull out any grease items. Will do that before it goes back together.
And I found a tpi setup. Its missing the wireharness, so thats all I need anymore.
kurfbird
PostPosted: Thu May 24, 2007 5:52 pm    Post subject: Lock Actuator Reply with quote
Grease and oil everything up. I used Yield spray lub and mine started working great. And I had the same problem at different times.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
