Posted: Wed May 23, 2007 4:26 am Post subject: misc parts WTB, mostly TPI |
looking for some parts, no major hurry. Price is more an issue then finding or time. All for 91 Camaro
36mm Front sway
black door sill plate
right side GM power lock
pwr window switch
2 left, and 2 right 82-87?? style tail lights. 2 could be broke in certin areas.
TPI Parts:
91-92 harness
custom burned prom to fit moates G3 adaptor to get me started
used stuff to burn my own chips
Posted: Wed May 23, 2007 7:17 am Post subject: |
| Kurfbird might have a lot of these parts. He JUST sold a TPI unit and is in the market of scraping 3rd gens. |
Posted: Wed May 23, 2007 7:38 am Post subject: Re: misc parts WTB, mostly TPI |
| 91RSVert wrote: | | right side GM power lock |
Do you want the cylinder, the actuator, the harness, the linkage? There are a lot of parts in those locks. |
kurfbird Member
Posted: Wed May 23, 2007 7:41 am Post subject: Parts |
I am not in the market to scraping third gens . But I do have some parts.
I only have the throttle bracket for the TPI. Everything else is gone. Sorry. _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Wed May 23, 2007 9:37 am Post subject: Re: misc parts WTB, mostly TPI |
| aaron_sK wrote: | | 91RSVert wrote: | | right side GM power lock |
The actuator, sorry. I have to hit the lock button several times to make it do whats needed. |
Posted: Wed May 23, 2007 9:39 am Post subject: Re: Parts |
| kurfbird wrote: |
I only have the throttle bracket for the TPI. Everything else is gone. Sorry. |
Got any of the other non tpi parts?
If you *cough* come across some of the other parts on a car, please keep me in mind. |
Posted: Wed May 23, 2007 9:47 am Post subject: |
| I have couple of tail-lights that are the late model RS type, with the black stripe. Not exactly the same as the early ones, but clsoe. |
kurfbird Member
Posted: Wed May 23, 2007 9:57 am Post subject: Parts |
I might have the aucator and power mirror switch. I will check tonight and get back to you. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
kurfbird Member
Posted: Wed May 23, 2007 10:00 am Post subject: Actuator |
You might want to take you door panels off and lubricatre everything really well. Mine was doing that and I used some spray lub and now it works great.
ALso the actuator peices that goes on the door rod inside the door itself spreads out over time. I took mine off and pinched it back together with vice gripes and that helped alot. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Wed May 23, 2007 11:02 am Post subject: Re: Parts |
| kurfbird wrote: | | I might have the aucator and power mirror switch. I will check tonight and get back to you. |
Window switch, not mirror switch.
Door panels are off right now, so I'll look at the linkages. Door rod spreads out?? Kinda confused on that. |
kurfbird Member
Posted: Wed May 23, 2007 11:58 am Post subject: Door linkage. |
Look where the linkage goes into the lock actuator. Looks like a Y peice of emtal with a clamp like opening _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Thu May 24, 2007 3:53 am Post subject: |
| ok, will look at this tonight. |
Posted: Thu May 24, 2007 5:43 pm Post subject: |
ok, I see what you mean on spreads out. Its no bigger then the left side. Since I was spraying primer tonight, I didnt want to pull out any grease items. Will do that before it goes back together.
And I found a tpi setup. Its missing the wireharness, so thats all I need anymore. |
kurfbird Member
Posted: Thu May 24, 2007 5:52 pm Post subject: Lock Actuator |
Grease and oil everything up. I used Yield spray lub and mine started working great. And I had the same problem at different times. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
