Posted: Fri May 04, 2007 7:01 am Post subject: Gimped Fuel line |
I did a search but couldn't find it. I think Tony had this problem?
Damn fuel line. This goes between the pump and the pickup tube. Fixed it with EFI line and now my LT1 runs again! _________________ E30
Posted: Fri May 04, 2007 8:00 am Post subject: |
That would have been me!
Posted: Fri May 04, 2007 8:47 am Post subject: |
WTF? How did you give my car your sickness over the interweb? Lol.
I was totally thinking that was the problem so that was the first spot I looked after verifying the fuel pressure. Luckily for me, it flowed enough to empty the tank (which was full) by disconnecting the fuel line by the engine. I keep a spare pump with a hose now just in case.
20 years isn't bad for a submerged fuel line though huh? It had a good run, what can I say. Pretty hard to be mad at it. |
Posted: Fri May 04, 2007 12:37 pm Post subject: |
I was mad at mine, because i had replaced the fuel pump first, then put it back together, before I found that was the issue!!
(ok, I am more mad at myself, for not noticing it when I put everything together.) |
