Gimped Fuel line
PostPosted: Fri May 04, 2007 7:01 am    Post subject: Gimped Fuel line Reply with quote
I did a search but couldn't find it. I think Tony had this problem?
Damn fuel line. This goes between the pump and the pickup tube. Fixed it with EFI line and now my LT1 runs again!
PostPosted: Fri May 04, 2007 8:00 am    Post subject: Reply with quote
That would have been me!
PostPosted: Fri May 04, 2007 8:47 am    Post subject: Reply with quote
WTF? How did you give my car your sickness over the interweb? Lol.
I was totally thinking that was the problem so that was the first spot I looked after verifying the fuel pressure. Luckily for me, it flowed enough to empty the tank (which was full) by disconnecting the fuel line by the engine. I keep a spare pump with a hose now just in case.
20 years isn't bad for a submerged fuel line though huh? It had a good run, what can I say. Pretty hard to be mad at it.
PostPosted: Fri May 04, 2007 12:37 pm    Post subject: Reply with quote
I was mad at mine, because i had replaced the fuel pump first, then put it back together, before I found that was the issue!!
(ok, I am more mad at myself, for not noticing it when I put everything together.)
