not F-body but this is a test for my iroc paint
90droptoproc
PostPosted: Mon Apr 16, 2007 2:36 am    Post subject: not F-body but this is a test for my iroc paint Reply with quote
I have been slowly building up all my supplies and tools and such to repaint my Vert for abit now, and due to its daily driver status I will be doing it in stages (meaning I will bodywork and spray a section at a time so I can drive it home from my work area each night)
I started the actual work today and got the left fender, door, and quarter done before I had to clean up for the day.
I am getting rid of the tu-tone as you can see, and some things like the handles and trim and such are being painted also (not my idea, the last repaint covered em all, so now I gotta)
does anyone here have any knowledge on colorsanding an acrylic enamel singlestage paint, I need to know how long to wait till I can sand it smoother.
before
after todays work
and a quick photochop for a concept
please be gentle, after all it was a really crappy midnight cranberry flaking paint job before.
but I would like to know about the time needed to fully cure and any opinions people might have,
thanks
Rich
PostPosted: Mon Apr 16, 2007 7:09 am    Post subject: Reply with quote
I like it.
I dont think that the enamel will dry hard enough to sand. But if its possible, i would wait at least two weeks, especially with the cold weather. Looks good though!
PS. The gray seats I still have in my garage look EXACTLY like what you have in the Cavi.
PostPosted: Mon Apr 16, 2007 8:36 pm    Post subject: Reply with quote
Been awhile since I looked any of this up.. But if I remember right it had to cure a month before color sanding/buffing. Of course that will also depend on what hardener you use. My last single stage job I used a urethane hardener in the enamel. Came out much glossier then the standard hardener.
PostPosted: Mon Apr 16, 2007 8:44 pm    Post subject: Reply with quote
Actually looks pretty good. Smile
PostPosted: Mon Apr 16, 2007 9:59 pm    Post subject: Reply with quote
looks good to me.
PostPosted: Mon Apr 16, 2007 10:35 pm    Post subject: Reply with quote
looks pretty good to me Rich!
90droptoproc
PostPosted: Tue Apr 17, 2007 12:33 am    Post subject: Reply with quote
WOW!!! thanks guys, I was really expecting to get burned for working on a fwd beater Laughing
90droptoproc
PostPosted: Thu Apr 19, 2007 2:31 pm    Post subject: Reply with quote
so I finnaly got to talk to the owner of the paintshop at my work(uses the same paint all day) and he says it should be fine to colorsand anytime after 2 days so I am just waiting for some time to get out there and do it Very Happy
I hope it turns out ok, but the bodywork on the door is pretty bad, I want to find a replacement, but it is hard to find vert parts around here right now Sad
90droptoproc
PostPosted: Tue May 15, 2007 11:41 am    Post subject: Reply with quote
well I havnt done much more with the paint, but here is an update
this is it after the paint and before anymore work
I changed out the rear trunklid and added the later model wing
and then I made my new hood hinges
PostPosted: Tue May 15, 2007 12:55 pm    Post subject: Reply with quote
Shocked
Rich, what did you do to your hood?
PostPosted: Tue May 15, 2007 9:27 pm    Post subject: Reply with quote
I've kinda wanted to do that to my bird. You should try it and then sell me the hinges. Smile
90droptoproc
PostPosted: Wed May 16, 2007 12:56 am    Post subject: Reply with quote
Ian, that reminds me, afew people have asked me to do this for them around here locally, what do you think I should charge for this as a drive in and drive out type of thing?
PostPosted: Wed May 16, 2007 8:44 am    Post subject: Reply with quote
Oh man I have no idea, how long does it take you to do?
90droptoproc
PostPosted: Thu May 17, 2007 9:50 am    Post subject: Reply with quote
few hours, I would like to set aside a day to be sure
PostPosted: Thu May 17, 2007 11:09 am    Post subject: Reply with quote
what hinges did you use? They look like camaro hinges.
90droptoproc
PostPosted: Thu May 17, 2007 1:18 pm    Post subject: Reply with quote
LOL no they don't trav!!
they are buick hinges, you should come up this weekend and check em out in person Very Happy
PostPosted: Thu May 17, 2007 1:41 pm    Post subject: Reply with quote
I should huh? We're brewing more beer this weekend. Lol. What ever day I don't brew I'll try to come up.
How do you stop the hood from hitting the front bumper? Looks like its got some angle there.
PostPosted: Thu May 17, 2007 10:45 pm    Post subject: Reply with quote
Are those from a mid 80's buick? I think I've got a set of those. It's originally got the crossbar that connects each side. Got more pictures? Couple hundred per job if it's a from scratch thing and less if you've done it before? No idea on pricing.
90droptoproc
PostPosted: Fri May 18, 2007 1:52 pm    Post subject: Reply with quote
yup those are the hinges
90droptoproc
PostPosted: Fri May 18, 2007 1:57 pm    Post subject: Reply with quote
there is a stop I built into them to stop it from pivoting in one direction and it rests on the top of the grill in the other rotational direction
_____
....../o
__/_
ignore the periods
