AC DELETE BOX AND FAN
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Sun Apr 15, 2007 4:08 pm    Post subject: AC DELETE BOX AND FAN Reply with quote
Ok, we need an ac delete box, and a fan...
Time to do this while the motor is out.
thanks
scott
PostPosted: Sun Apr 15, 2007 4:19 pm    Post subject: Reply with quote
If it helps I have a fan and cage (no box), plus a cut wiring harness (only about six inches). Fan is a little noisy, but it blows.
scott in wa.
PostPosted: Sun Apr 15, 2007 4:33 pm    Post subject: COOL Reply with quote
Well, ya.
I could put new bearings in it right?
This is the ones that is made for the AC delete box right? the other will not work. From what I here its a hole different setup..
If so, ya I will take it, as long as I can fix it.
thanks
scott
PostPosted: Sun Apr 15, 2007 4:40 pm    Post subject: Reply with quote
Well, either motor will work, but you need the right shaft length and cage.
I bought my delete box with this motor in it, but it was noisy so I took it out. I got my old motor (which worked great) and put a different short cage on it (from an '89 Bonneville IIRC) and it seems to fit fine.
The problem with reusing the AC motor is that the shaft is to long for the short-shaft cage on the delete box. So you need either a short shaft motor for the cage, or a short cage that can take a longer shaft.
Confusing, I know. Rolling Eyes
Mind if I swing by tomorrow after work (4:30-ish)? You still live in the cul-de-sac in Puyallup?
PostPosted: Sun Apr 15, 2007 11:54 pm    Post subject: Reply with quote
if you space it out a little bit you can use the AC motor, but i would not recommend it. you can get NEW ones with the fan from NAPA/schmucks ETC for a reasonable price.
